JLG T350 Lift
   / JLG T350 Lift #1
JJZ 109
Veteran Member
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
Bought one of these last summer. Great machine for what I do.
I removed the batteries (4 six volt) from the machine to keep them on a battery tender in the garage all winter. Now I can't remember which cables go where.
There are two long leads on each side of the machine from inside. Both cables on one side say "Battery - left side". So I attached both to the negative terminals on the left side batteries. Then there is a short cable that I attached between the positives on those batteries.
On the other side of the machine there are two cables labeled "Battery + right side". I attached them both to the positive terminals. Then I used the supplied short cable to attach the negatives on those 2 batteries.
No go. No power to anything. Batteries are fully charged and terminals are clean. If I plug the internal charger in, it goes through its red/green/yellow light test sequence and then the red light constantly gives 2 flashes. That indicates low voltage according to the manual.
Does anyone know what I've got goofed up or have a diagram of how these 4 batteries are hooked up? I came up with a manual here, but it only mentions battery maintenance and terminal cleaning.
I guess this knucklehead should have marked things before removal!
   / JLG T350 Lift #2
   / JLG T350 Lift
Scooted up to a local rental place where a friend works. They've got 2 of the same model so I went up and made a diagram. Heading out to the garage now to see what I've got.
   / JLG T350 Lift
The 15 minute ride up to look at other T350s was worth it. Batteries back in, hooked up correctly and lift operational.
Haste is not your friend. :confused2:
JCT 84" Rock Grapple (A50121)
JCT 84" Rock...
1996 Lincoln Town Car Signature Sedan (A50324)
1996 Lincoln Town...
2015 Jeep Renegade Latitude SUV (A50324)
2015 Jeep Renegade...
2018 FABRIQUE 20FT TRAILER (A52141)
2018 FABRIQUE 20FT...
2019 John Deere 5090E (A50120)
2019 John Deere...
2012 UTILITY VS2DX 53FT DRY VAN TRAILER (A52141)
2012 UTILITY VS2DX...
