JLG Lift Turret won't pivot when hot
   / JLG Lift Turret won't pivot when hot #1
denisongolden
Denison Golden
I have a '99 JLG 600A lift. My problem is after about a half hour of use, the turret will only pivot one way. Normal speed left but really slow or not at all to the right. Is this a directional control valve issue or the hydraulic motor itself? One mechanic told me to use a heavier oil but to me that's just a bandaid. Any thoughts?
   / JLG Lift Turret won't pivot when hot #2
If works one direction and not the other I would first suspect a valve issue since motor would be common parts turning either direction.
Thank you oldnslo. That helps me a lot. The control valve is much easier to work on that's for sure!
   / JLG Lift Turret won't pivot when hot #4
I hope my suspicion is accurate. What style of valves are the ones used for rotation? Is it a single valve with two coils or two separate valves? The first thing I would check is took make sure both coils are good.
   / JLG Lift Turret won't pivot when hot #5
I would check that the hydraulic motor for the turret is properly attached and tightened. My motor has a difficult to adjust and keep adjusted mounting system that uses 3 heavy bolts. When it gets loose it can move more in one direction than the other because of the way the mounting system works. If yours is similar I could imagine it might turn normally in one direction but get bound up in the other.
Electric Concrete Mixer (A51573)
Electric Concrete...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
2018 Nissan Titan Pickup Truck, VIN # 1N6AA1E57JN515039 (A51572)
2018 Nissan Titan...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2025 New/Unused Wolverine 32in Hydraulic Backhoe Excavator (A51573)
2025 New/Unused...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
