jj or anyone help please
   / jj or anyone help please #1
rayclar
prince township , ontario, canada
kubota 4310hstc
Ive read many post about kubota loader valves that freeze up and they say to drill a 3/32 hole to drain the water. Is that to drill on the end that the cables hook to or the opposite side? also i have a l4310hstc model Thanks ray
   / jj or anyone help please #2
They are talking about the caps on the bottom of the valve that cover the float section and other add-ons.
You can also fill the caps with some waterproof grease.
   / jj or anyone help please #3
Agree with JJ - I'd go with the grease. Everything around my place with a hole big enough to drain water also seems to attract bugs looking for a new home... Steve
UPDATE , today i drilled a 3/32 hole in each cap. It drained about 1/2 oz of water from each. Then flushed them with wd40 and moved the control every which way possible. All done still on tractor. Hopefully this will solve the freezing problems i had. No grease as im going to block the holes with rubber patch and hose clamps. Then if it needs flushing with wd40 i just have to remove the clamps. Thank all. ray
   / jj or anyone help please #5
Try Fluid film or PB Blaster, MUCHO better than WD40 as a lubricants.
Kenny where are these available? tractor supply or walmart or automotive parts stores?
   / jj or anyone help please #7
Fluid film is sold at most JD dealers, PB Blaster is available almost anywhere.
2011 DOOSAN G40 GENERATOR (A53843)
2011 DOOSAN G40...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2022 Toro Workman 07921 Electric Utility Cart (A54811)
2022 Toro Workman...
Utility Trailer (A52377)
Utility Trailer...
