Jinman 284 Brush guard:
   / Jinman 284 Brush guard: #1
yugo
Lawrence, KS
Farm Pro 2425, Ford 8N
Just wanted show the bush guard I built for the jinman 284. Since we don't have a FEL to knock down the brush & weeds, I built this to protect the power steering cylinder and rubber boot. Why they put the ps cylinder in front of the axle, I'll never know. Please see attachment. Yugo
   / Jinman 284 Brush guard: #2
Nice Work! That should do the trick! I had the same concerns when I got mine. Since I am welding challenged, I made sure I had a complete spare set. To date, the biggest problem has been the rubber boot. It pulls off easily from either end, and have a few minor tears. I'll replace it, this spring, and use good hose clamps vs the wire clamps.
   / Jinman 284 Brush guard: #3
Wow /forums/images/graemlins/smirk.gif that really is a nice job, well done. A welder is on my wish list of things to buy someday. I work for a machine shop and can get all the steel I could use, but would like to get a torch and an AC-DC welder. Looks like you had some fun making it.
   / Jinman 284 Brush guard: #4
Rick,Have you considered a mig welder? After getting one I found I never fired up the old stick welder again.
After seeing this brush guard , I know what my next project is going to be.
Billy
   / Jinman 284 Brush guard: #5
Looks very nice, with those lights there it makes it look really different from others and "TOUGH"
   / Jinman 284 Brush guard: #6
Very well thought out. Great idea with the hitch and lights. Great job!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
   / Jinman 284 Brush guard: #7
Billy,
Is the mig welder really that much better than stick. I have a 225 amp AC stick and have not met any metal it won't weld. Though my welds aren't the prettiest they hold. Does a mig welder give you better welds? What might be an advantage over stick?
   / Jinman 284 Brush guard: #8
Steve, I had a 225 Lincoln for years and it always did a good job and never let me down. That said when I got the Mig I think it is just so handy and does a realy nice job that I just never used the old Lincoln any more . Its sorta like my old 8-N ford, it was a good old tractor but after I bought the Farm Pro I just didn't use it any more. So I don't know, if you have a good stick machine stick with it but if I were buying my first welder I would take a good look at Mig.
Billy
   / Jinman 284 Brush guard: #9
Very nice!
Soundguy
   / Jinman 284 Brush guard: #10
You're going to bust those lights, I talk'n from first hand experience. The way I protected mine was to make a steel frame using flat stock and expanded metal over the lens, so that when I got to some brush, well, you know why. We have lots of yopon here, and that darn stuff can get into all parts of the tractor, and break stuff I did not know could be broken.
Good Luck and have Fun!
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
INVERTER TIG 350A WELDER (A51248)
INVERTER TIG 350A...
Case CX80C (A50123)
Case CX80C (A50123)
UNUSED FUTURE CG34 - 34" HYD CLAMP GRABBER (A51248)
UNUSED FUTURE CG34...
2023 JOHN DEERE 8R310 LOT IDENTIFIER 131 (A53084)
2023 JOHN DEERE...
