Jinma won't go into Hi range
   / Jinma won't go into Hi range #1
GeorgiaJohn
Kingston
Mahindra 1626
I have a Nortrack 2454. I understand it is actually a Jinma. The tractor runs fine in low range but will not shift into hi range. Took the cover off and can not see anything unusual. Forks are good it just seems that it dosen't go far enough forward to engage. When you shift into hi it is in neutral and if you push forward on the lever it makes a grinding sound. Any help will be greatly appreciated.
   / Jinma won't go into Hi range #2
Since you have had it apart and dont see anything suspect, I would contact Tommy at Affordable Tractor Sales and run it by him. I doubt there is anything he hasn't yet seen with Jinma tractors.
Affordable Tractor Sales Co. LLC
6972 Highway 36 North
Bellville, TX 77418
Phone: (979) 865-4002
Fax: (979) 865-5183
Is it possible that the splint ring in front of the big gear could have expanded and is keeping the gear from going forward? That is the only thing we can see without spliting the tractor.
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2011 VANGUARD 53x102 DRY VAN (A53426)
2011 VANGUARD...
HAMM HD+120I DOUBLE DRUM ROLLER (A51246)
HAMM HD+120I...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A51247)
UNUSED CFG...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
