Jinma Tractor won't start
   / Jinma Tractor won't start #1
jb7919
Rockford, Illinois
2002 Jinma 284,
While adding diesel to my Jinma 254 tractor I was warming the glow plugs. The tractor had "juice" at this time as the battery was on and gas gauge indicated it went from 1/4 to a full tank. I went to start the engine and nothing happened. No clicks, no sound, nothing. Now the needle on the gas gauge does not even move past the E mark for empty.
I put a battery charger on it for several hours and again nothing.
Any suggestions to what is wrong or get this engine started would be appreciated.
Thank you.
JB
   / Jinma Tractor won't start #2
the first thing that comes to my mind when reading your post is , either bad ground at the frame or blown main fuse.
   / Jinma Tractor won't start #3
Bypass clutch switch briefly to see if thats the culprit. Mines been out for a year and it was a new one and only lasted 1 year. bjr
Thank you for the help. Ground is okay. I identified a blown 30amp fuse. You were most helpful! Thanks again.
Clutch was not the culprit. Problem was a blown fuse. Thanks for the input.
jb7919
2021 JOHN DEERE 8R250 LOT NUMBER 193 (A53084)
2021 JOHN DEERE...
2012 PETERBILT 587 SLEEPER (A52577)
2012 PETERBILT 587...
BAUMA LIGHT TX 12 LOT NUMBER 240 (A53084)
BAUMA LIGHT TX 12...
2020 JOHN DEERE 7R210 LOT NUMBER 47 (A53084)
2020 JOHN DEERE...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
New/Unused Gold Mountain Shelter 20ft x 30ft (A51573)
New/Unused Gold...
