jinma repair in central illinois
   / jinma repair in central illinois #1
dcurl796
jinma 200
my jinma has been a problem since warranty
went out, replaced key switch, replaced starter, replaced injectors. boiled out fuel tank cleaned all lines replaced all filters. now tractor turns over but will not start. blows white smoke. am fed up need a mechanic. know anyone in central Illinois?
   / jinma repair in central illinois #2
White smoke is unburned fuel if it lingers in the air which could be dribbling injector(s) or fuel pump timing that is too retarded from spec. Whitish smoke that dissipates rapidly is condensation from a cold combustion chamber or coolant from a leak into the combustion chamber.
   / jinma repair in central illinois #3
What was the original problem that caused you to "replaced key switch, replaced starter, replaced injectors. boiled out fuel tank cleaned all lines replaced all filters"?
//greg//
junk in tank, switch went bad replaced 1/2 wiring bad connectors shorts blown fuses. water in starter rebuilt still wouldn't turn over replaced starter tuned over fine. no start thought injectors might be clogged so replaced. i'm not a mechanic but can follow books well. problem no books no pictures
white smoke lingers have to open doors and air out. would timing change without me removing any parts. starter only thing replaced. please give info and pictures on timing. note engine won't start to check at specific rpm
   / jinma repair in central illinois #6
Timing on this diesel engine is done by loosening the injection pump mount slightly, just enough to be able to move it by hand (toward and away from the engine block). If you find it already loose, that could explain why it's not starting. The specific procedure to fine tune the timing should be in your Y80 Operations & Maintenance manual under "Adjustment of Injection Timing".
//greg//
   / jinma repair in central illinois #7
I have not ever seen the bolts loosen up enough to change the timing,the gear on the front of the injection pump is slotted,this is where you can adjust the timing of the pump ( If it is out of timing) the mounting bolts greg_g is talking about would only allow for a small amount of tweating at best. Most of the time the white smoke is associated with moisture either from water in the fuel or from water in the cylinders.I would not try to adjust anything on the fuel injector pump if you are not qualified to do so, you could make this worst than it already is.These tractors have been proven to be very reliable with little minor issues that most owners can take care of.If you call our office 979-865-4002 we have a dealer list that we can try to help you locate a dealer near you to help get you going.No matter what it is we can help with the parts if needed
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
will have to pull radiator to check timing view totally blocked. bled lines at injectors again and getting black smoke now but will not start . caught a couple of times . what's next
   / jinma repair in central illinois #9
You've gone from white smoke to black smoke, right? Sounds to me as though you may have had some condensation or leaked coolant in your cylinders that has now been mostly purged but it may have gooked up your injectors, particularly if that moisture came by way of contaminated fuel system. I'd pull the injectors and soak them in some cleaner and then check the spray pattern outside the engine before re-installing them. If there is any suspicion on injector problems I'd probably order a couple new ones and try them. Other than soaking them a bit in cleaner, there is nothing you can do to them other than replace them, which you have already done - but there may have been crud in the cylinders or the fuel system that affected the new injectors, so I'd soak them and see if it helps. Have you put fuel treatment in your new fuel?
   / jinma repair in central illinois #10
We are a full service Jinma dealership, with onsite mechanics that know these tractors inside and out. They are very good at trouble shooting problems over the phone. Give us a call and I am sure our mechanics can help.
Nan
Parts Dept.
Keno Tractors
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2015 FREIGHTLINER...
UNUSED CFG QK18R EXCAVATOR (A51247)
UNUSED CFG QK18R...
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
48" Pallet Forks  (A52384)
48" Pallet Forks...
