Jinma rebuild questions?
   / Jinma rebuild questions? #1
thetester
Bronze Member
Benton MS
3414 IH
I had freshly rebuild my jinma farm pro 2420 last summer. Had very little hours on it. Checked the oil this spring and it was full of antifreeze.
I tore this thing Down and inspected it with a fine tooth comb. No cracks nada. I added pressure to the coolant side and it seemed to be leaking from around the sleeves.
I got new sleeve orings and they look smallish for a good seal. They are in fact new and correct. I polished up the bore area for sure with steel wool and skotch brite. I put the rings on and added soap. I can seat the sleeves by hand.
This worries me because I had leaking antifreeze from the seals before.
The old orings were not rolled or cut. Just swollen and mushed flat. No sign of why they would leak.
Should I attempt to source fatter or thicker orings for a more press fit??
Opinions and suggestions??
   / Jinma rebuild questions? #2
I'd check the concentricity and perpendicular alignment of the block bore against the block deck. Could be that the bore is slightly ovaled.
   / Jinma rebuild questions? #3
Also, the liner should not be able to be pressed in just by hand. You probably need slightly larger silicone O-rings and press the liner in with a slotted bar against a headbolt/stud, pressing on a block of wood against the liner. Here is a suggestion for the tool.
2022 Club Car...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2001 Ford Excursion Limited SUV (A48082)
2001 Ford...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2025 KJ K1230 UNUSED (10) Wire Mesh Netting Rolls (A50860)
2025 KJ K1230...
2017 Ford Taurus SEL Sedan (A48082)
2017 Ford Taurus...
