Jinma lw 8 backhoe ordering replacements seals….over or under sized?
   / Jinma lw 8 backhoe ordering replacements seals….over or under sized? #1
DonRina
Vancouver Island
Jinma 354
In measuring my Jinma Chinese LW 8 backhoe hydraulic parts in order to find replacement seals I’m wondering where I place the slop of the measurements.
For example, gland nut o rings. I get 64.5 mm ID on the part and 70.15mm for the cylinder wall id. So would a 64mm I’d x 4mm t work? Similar issues for the feast of the parts. Can’t quite get to the measured sizes vs what’s available. Too bad kits are not available or info from others going down this path.
   / Jinma lw 8 backhoe ordering replacements seals….over or under sized? #2
If you don’t have the original seals then Measure the glad or groove the seal goes in both width and depth along with seal dimensions. Then do a search for gland dimensions for O-rings in both static and dynamic operation. Parker and Apple Rubber both used to have decent websites but have not looked at either for a few years. This will provide you nominal dimensions for a given O-ring.
Seal squeeze will vary from static to dynamic
John Deere 21ft. Implement Trailer (A49339)
John Deere 21ft...
H&S 2606 Manure Spreader (A49251)
H&S 2606 Manure...
2019 Ford Explorer AWD SUV (A46684)
2019 Ford Explorer...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A46684)
2016 Chevrolet...
2011 John Deere Z Trak Pro Z925A 60in Zero Turn Mower (A46684)
2011 John Deere Z...
72in Large Capacity Bucket (A49251)
72in Large...
