Jinma lost all hydraulics
   / Jinma lost all hydraulics #1
steamer
Edson, alberta
Jinma
I have lost my power steering 3PH and FEL. The quit at the same time for no apparent reason. I know this has happened to some one before.
Any advice / direction would be much appreciated.
   / Jinma lost all hydraulics #2
Have you chcked fluid level? If ok, change the filter. Does it try to work a little or does it do nothing @ all?
   / Jinma lost all hydraulics #4
Make sure there is good flow to the pump inlet. You can disconnect the inlet line at the pump to check it.
You can pull the pump to make sure the pump drive coupling is intact. If your power steering is a separate pump and both systems failed at once this may be the problem.
2006 UNKNOWN 16 T/A TRASH TRAILER (A53843)
2006 UNKNOWN 16...
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
197711 (A51244)
197711 (A51244)
Hose Reel (A53424)
Hose Reel (A53424)
2019 VOLVO TRUCK VNL (A53843)
2019 VOLVO TRUCK...
1270 (A50490)
1270 (A50490)
