Jinma / JW03 Backhoe Hydraulic pressure release valve
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #1
IBPALLETS
S Central VA
Jinma 284 and Mahindra 3616
When you take this apart for checking you drop the bottom bowl which is the adjustment- then on top is a screw out threaded cover which you remove . Do the in between parts come out pushing from the top or bottom ? They dont seem to want to come out and dont want to force something. ?
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #2
I have the exact same question, hopefully someone with experience will chime in.
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #3
Do you have symptoms that might require disassembly? If so, what? They aren't part of routine service.
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #4
In my case I have a non-functioning backhoe. Oil is flowing fine from the pump and through the reservoir, but absolutely zero response from the controls.
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #5
What were you doing when this symptom started?
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #6
I bought the backhoe in this condition. Cheap. I'm talking "Just get it outta my yard!" cheap.
The backhoe is not currently connected to the tractor, and I'm not likely to begin working on it until all the other spring tractor chores are done, so I'm just exploring ideas for a fix.
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #7
There is an acorn nut on your valve stack, remove it, then loosen the lock nut. With a screwdriver, remove the adjusting screw being careful to count the number of turns (write it down). Remove the spring and plunger (or ball) and inspect for debris. Reassemble in reverse order being careful to count the number of turns against the spring as this controls your operating pressure of around 2,500 psig.
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #8
When I had that backhoe I had the same issue. Nothing worked. What the issue was a O ring had sucked through the line. It stuck in the pressure release value. So it was bypassing and it would not allow flow to any cylinders. That would be my first thing to check.
Well we got it apart with tractor mech help - now we have another problem one part fell into the hole from hell where ever that is . looked three days and cant find - anybody have a junked control box they want to parts out - And BTW there was chewed up O ring which has been my problem before . now I have a new one.
ANY BODY WITH A SCRAPED CONTROL BOX THEY WANT TO MOVE I DOUBT THATS A ORDER PART ???
   / Jinma / JW03 Backhoe Hydraulic pressure release valve #10
The term "control box" might confuse some. There are lots of backhoe valve stacks available. Quality will vary. I think a Prince valve stack will run North of $600. Here is a budget model.
2016 Nissan Sentra Sedan (A51694)
2016 Nissan Sentra...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
1266 (A50490)
1266 (A50490)
JOHN DEERE Q820M LOT IDENTIFIER 229 (A53084)
JOHN DEERE Q820M...
UNUSED FUTURE FT-BC63 63" HYD BRUSH CUTTER (A51248)
UNUSED FUTURE...
LMC LOT IDENTIFIER 131 (A53084)
LMC LOT IDENTIFIER...
