Jinma Hydraulic Leak
   / Jinma Hydraulic Leak #1
ryanrancher
Jinma 25hp
I have a jinma tractor that has a hydraulic leak leak. I have a picture of where it is leaking but i dont know how to post a picture. Also, i am wanting to know what is the best way to fix it.
thank you!
   / Jinma Hydraulic Leak #2
Is it the transmission, rear end, hyd pump, etc?
Is it a flange leaking or a pipe leaking, or a hose or fitting?
Need more data.
Just might need tighten some.
If it is a gasket or seal, just replace it.
I think it was a seal. I took it apart and replaced it with a new o-ring. The front end loader barely moves up now, but i am assuming it is because there is not enough hydraulic fluid in the system. Does that make sense? I am going to get some more hydraulic fluid tomorrow and will find out.
Thank you! I appreciate it.
Does anyone know what kind of Hydraulic oil I should get? is there a specific type for the jinma tractors?
   / Jinma Hydraulic Leak #5
Refill to the correct level. and cycle all the cylinders until the air is purged.
Thanks JJ. I'm new to the whole tractor thing so thanks for all the great info.
How do i cycle all the cylinders to purge the air out?
   / Jinma Hydraulic Leak #7
Just raise and lower the lift arms and curl and uncurl the bucket.
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
Light Tower (A52377)
Gateway Monitor (A51695)
Gateway Monitor...
2007 Ford F750 Forestry Chipper Truck (A52377)
2007 Ford F750...
2015 Hooper T/A Trailer w/Mounted Foaming System (A53117)
2015 Hooper T/A...
