Jinma Hydraulic Leak
   / Jinma Hydraulic Leak #1
ryanrancher
Jinma 25hp
I have a jinma tractor that has a hydraulic leak leak. I have a picture of where it is leaking but i dont know how to post a picture. Also, i am wanting to know what is the best way to fix it.
thank you!
   / Jinma Hydraulic Leak #2
Is it the transmission, rear end, hyd pump, etc?
Is it a flange leaking or a pipe leaking, or a hose or fitting?
Need more data.
Just might need tighten some.
If it is a gasket or seal, just replace it.
I think it was a seal. I took it apart and replaced it with a new o-ring. The front end loader barely moves up now, but i am assuming it is because there is not enough hydraulic fluid in the system. Does that make sense? I am going to get some more hydraulic fluid tomorrow and will find out.
Thank you! I appreciate it.
Does anyone know what kind of Hydraulic oil I should get? is there a specific type for the jinma tractors?
   / Jinma Hydraulic Leak #5
Refill to the correct level. and cycle all the cylinders until the air is purged.
Thanks JJ. I'm new to the whole tractor thing so thanks for all the great info.
How do i cycle all the cylinders to purge the air out?
   / Jinma Hydraulic Leak #7
Just raise and lower the lift arms and curl and uncurl the bucket.
2014 Dodge Avenger Sedan (A53424)
2014 Dodge Avenger...
2022 BMW SUV (A53424)
2025 K0608G UNUSED 3-Rail Style Fence (A53117)
2025 K0608G UNUSED...
2018 FORREST RIVER CRUISE LITE CAMPER (A53843)
2018 FORREST RIVER...
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
