Jinma chipper feeder drum belt replacement
/ Jinma chipper feeder drum belt replacement #1
billsanfilippo
ford 800 kubota L3400
I recently picked up a Tytan wood chipper here on the Big Island of Hawaii. The research I have done on line shows it is identical to a Jinma 6". Have not been able to find a repair manual for either a Tytan or a Jinma' My question is changing the belt that drives the feeder drum. I have run he chipper and it works OK but the feeder belt is not long for this world and when I look at the pully that is attached to the main drive shaft there appears to be only 1/8-1/4" between the pully and metal behind it. Does not appear to be enough to slip a belt between the two??
Also while I'm at it any manual info on adjusting the feed roller etc. Thanks in advance
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
