Backhoe Jinma backhoe hydraulic fittings
   / Jinma backhoe hydraulic fittings #1
Amez
BC,Canada
Jinma 284
Does anyone know if crimp fittings are available for jinma backhoe type hoses? If I remember correctly they are an 8 mm thread for an o- ring face seal.(the o-ring is on the male threaded part fitting - the cylinders in this case. I am trying to avoid fabricating my own adapters.
Mike
   / Jinma backhoe hydraulic fittings #2
I think they are bigger than 8MM. If I recall, they are 18MM... I havn't had any luck in my searching for a compatible metric ORFS connectors or adapters.
The valve on my hoe uses a straight metric to ORFS adapter on all the ports. I can source all kinds of adapters to this straight metric port locally. I have pretty much resigned myself, that if I need a hose that I can't get from a dealer, that I will us a metric to SAE adapter at the valve, a SAE off the shelf hose, and weld a SAE fitting to the cylinder...
Good luck
Thanks guys
That looks like what I need. I am going to order and see.
   / Jinma backhoe hydraulic fittings #7
There is also one that has male 18x1.5 threads x #8 male JIC.
I think either one is about $20.00 a pop.
   / Jinma backhoe hydraulic fittings #8
Bob, do you have a part number for this one?
Has anyone actually used a 9022F? The description on the Adaptall website says it is a swivel, but when you click on the part number for a description, it says and shows a sloid fitting adapter. Is it actually a swivel fitting? I don't know how well a solid adapter would work. As I understand it, an O ring face seal is sandwitched between a flanged swivel connection, and a flat faced male metric fitting with a limiting groove or lip machined into the face. The clamp force is applied by the threaded collar over the flange and screwed onto the male threads. Using a solid adapter, the faces will be rotating as final torque is applied, and "O" ring might not like this situation...
   / Jinma backhoe hydraulic fittings #9
Yes, I used several of them awhile back when I converted all of my hydraulic valves. I'l dig through my paperwork and get the P/N.
I guess they call them a swivel because they can (I gave up trying to educate); some industry folks (me included) refer to them as a half-union because each end is one-half of a complete union of it's respective type.
Incidentally, the male x male adapter doesn't have an O-ring relief; I just used a copper washer - works great.
   / Jinma backhoe hydraulic fittings #10
Actually, that's exzctly how it works. Use silicone lube on the O-ring. Not a big deal.
And yes, they are solid.
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2016 FREIGHTLINER...
SHREDDER (A52472)
SHREDDER (A52472)
