Chipper Jinma 6" Chipper issue and parts
   / Jinma 6" Chipper issue and parts #1
Tim_in_IA
Platinum Member
Eastern Iowa
Kubota B7610HSD, Mahindra 6500 4WD, JD 440ic crawler, 2 560 farmalls.
I have a Jinma 6" PTO wood chipper. The joint that between the feed roller and the drive shaft is rounded on both ends. I see that they have upgraded the driveshaft from the style I have and that is available at circle tractors at least but I'm not seeing the roller anywhere. Any ideas on where to get these or if there is a tractor supplier in this forum could you let me know? I sent Tommy at Affordable Tractors an email based on old posts here but no reply so either Tommy isn't there anymore or Affordable Tractors is gone also? Was hoping this would not be as expensive as it appears it is going to be. I do have a welder but I'm less than a novice.
Thank you
   / Jinma 6" Chipper issue and parts #2
I have found better response from Affordable by phone rather than email.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 KENWORTH T800 HOTOILER (A58214)
2018 KENWORTH T800...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
2007 Volvo VNL Truck Tractor (A56435)
2007 Volvo VNL...
20ft Shipping Container (A57453)
20ft Shipping...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58017)
2015 FREIGHTLINER...
