Jinma 354 vs. Kama 354
   / Jinma 354 vs. Kama 354 #1
camman12
Henderson Nevada
2005 Jinma 45HP SL3105ABT
I am considering these two tractors. The Jinma 354 is a crate w/ FEL and BH for $12500 delivered. The Kama has the FEL for $12k and is put together, also delivered. But will have to purchase a BH seperately.
I will be using it for moving dirt around my two one acre lots. mostly.
camman12 /forums/images/graemlins/confused.gif
   / Jinma 354 vs. Kama 354 #2
That sounds like a lot of tractor for 2 one-acre lots. Have you looked at the 284 size? I have 7 1/2 acres of hill/woods and the 284 I got is almost more than I need. I got it so I won't be working it to death getting the land/jungle cleared back initially. After that it will be a little overkill. You could probably save a considerable ammount of money with the smaller tractor and still get a machine that would do a excellent job for you. As a backup, you save the money you didn't spend on the larger tractor(earning interest all the while:) and keep it for rental of a larger machine if you ever come across a job the smaller one can't do, or can't do quick enough.
Hi Ronmar,
Thanks for the quick reply /forums/images/graemlins/smile.gif
I was unsure about the digging capablities of smaller hp models. Here in LV, the material is med hard gravel/sand.
I was also noticing the price difference is only $1000/ $1500. Would the larger tractor resale be better?
   / Jinma 354 vs. Kama 354 #4
The KAMA TS254C will be more than enough tractor and will provide 8x8 shuttle (or creeper if you want to run a rototiller).
It is heavier than Jinma, but not as well supported nationwide if there is a kama dealer near you, take a look, if you are interested in a long distance purchase, and want a quote you can pm or email me.
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2007 INTERNATIONAL 4300 ROUSTABOUT (A52472)
2007 INTERNATIONAL...
2018 KENWORTH T370 REAR LOAD GARBAGE TRUCK (A52576)
2018 KENWORTH T370...
