Jinma 354 4wd 2012 540 PTO stuck on
   / Jinma 354 4wd 2012 540 PTO stuck on #1
Fishheads
Jinma 354 4wd
Hi all.
Hoping for some insight. I was running my PTO driven bush hog and the lever that changes from 540 - N - 1000 got stuck. I fiddled clutch in, clutch out and it started working again. Now I cannot get it to stop spinning in 540. Lever moves in the proper 3 option but it is always running on 540.
Any ideas ?
   / Jinma 354 4wd 2012 540 PTO stuck on #2
Check to see if the roll pin has been sheared off.
ok thank you ill take a look. Think there is a panel i can take off at the back to have a look. picture attached you think im alright to take off this panel ?
   / Jinma 354 4wd 2012 540 PTO stuck on #4
Ok, thank you ill take a look. Think there is a panel I can take off at the back to have a look. Picture attached. You think I'm alright to take off this panel ?
The roll pin I'm referring to will be at the base of the shift lever, not inside the case.
   / Jinma 354 4wd 2012 540 PTO stuck on #5
I don't have that panel on mine but I'm pretty sure it's for attaching a backhoe hydraulic pump.
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2016 FREIGHTLINER...
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
