Jinma 304 vs Jinma354
   / Jinma 304 vs Jinma354 #1
Momboy007
San Diego
Jinma 304
Hello All,
I am trying to get my clutch adjusted on my Jinma 304 and can mostly find procedures for the 354,
WHAT exactly are the differences?
Thanks in advance,
Rick
   / Jinma 304 vs Jinma354 #2
Momboy007 said:
Hello All,
Thanks in advance,
Rick
Same basic tractor, most likely to include the clutch. Main difference is horsepower. In some cases it's just a matter of how the engine is configured, in other cases it might be a 3 cylinder instead of a 4. So maintenance manuals on a 354 should be generally applicable to a 304. Expect possibly a different engine manual though.
//greg//
   / Jinma 304 vs Jinma354 #3
I think Greg is right. The same running gear and different engine.
Chris
   / Jinma 304 vs Jinma354 #4
As far as I can tell, the only real difference between a 304 and 354 are 5 horse power. (exact same engine) in the past there was the 3 cylinder TY395 engine. The injector settings are what made that engine a 30 horse or 35 horse. Importers would charge $$ for a 30 horse and $$$ for a 35 horse. All the factory did was install or adjust the injector pump for 30 or 35 horse.
Those 5 extra ponies come from the top end RPM, which is a simple matter of setting the throttle stop on the injector pump. A 304 top end RPM is 2000 and a 354 top end is 2300 RPM. On either configuration you could never tell the difference in power at or below 2000 RPM.
What is the exact model# on your engine? TY395E-1, TY395-E2, or TY395-E3
What is your top end RPM ?
Larry
Hi Larry, and thanks all for your help,
My top RPM, Where the Red Line is anyway on my Tach, is 2000, however, it will not make over 1800 RPM's since new!
I have a 3 Cylinder motor, I think an E-1 (don't quote me though)
I am going to try and adjust the clutch this Weekend, I do not think I have a problem, just want to check
Thanks again all,
Rick
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
Bobcat 60" Skidloader Sweeper (A50774)
Bobcat 60"...
2016 Ford Escape SE 4WD SUV (A50324)
2016 Ford Escape...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
