jinma 304 pto clutch?
   / jinma 304 pto clutch? #1
xamoman
vigeland
jinma 304
I have a 2005 jinma 304. It seems that i have a single stage clutch withought realy knowing what i am looking at but all the manuals and instructionals i have found show the Access panel on the left side. Mine is on the right. Is there not supposed to be a way to disengage and engage the pto other than the lever itself. (for eksample via the clutch)
   / jinma 304 pto clutch? #2
Try using the lever and clutch together.
After scratching my head for a whil i figured it out. I have a 2 stage clutch but there was absolutly no movement on the 2 stage. Some adjustments and vuala. Now it Works as it should. The main clutch slipps a little when yoe release the clutch pedal, but i think the problem there is a slightly worn clutch plate. Unless someone knows differently.
   / jinma 304 pto clutch? #4
Was the main clutch working ok(not slipping) before? Is the throw-out bearing sliding back far enough to completely disengage the lift fingers/levers on the clutch pack?
What I am getting at is that you may have adjusted the wrong thing, and you are going to kill your main clutch disc... There MUST be about 1/8" of gap between throw-out bearing and clutch fingers with your foot off the pedal. If the fingers are in contact/hanging on the throw-out bearing, you are not allowing full main pressure on the disc. This will also wear out the throw-out bearing...
The throw-out slides forward that 1/8"(pedal free travel) and pushes on the levers and lifts the main pressure plate. This relationship should result in a completely dis-engaged/released main disc by about 1/2 of your pedal travel.
The main pressure plate in turn lifts the PTO pressure plate to completely release it by the time the pedal is all the way down. If that 1/8" gap won't allow you to disengage the PTO disc, then you need to adjust the 3 bolts that control the relationship between the main and PTO plates.
Setup this way, you can have a PTO implement like a mower running at speed while you shift gears using only half of the clutch pedal travel... Here is a link to Johns jinma website and a clutch adjust procedure. Great pics showing the adjustment points. JMClutchAdj
2022 TAKEUCHI TL12R2 SKID STEER (A51246)
2022 TAKEUCHI...
2024 KMC 7406 (A53084)
2023 Ace Cargo 6x12 Food Trailer (A51572)
2023 Ace Cargo...
2018 Seal Rite SR 700XP Seal Trailer (A52384)
2018 Seal Rite SR...
JOHN DEERE R4023 LOT NUMBER 261 (A53084)
JOHN DEERE R4023...
2022 MGT CM11CUFT S/A Towable Concrete Mixer (A51691)
2022 MGT CM11CUFT...
