Jinma 284 PTO will not disengage
   / Jinma 284 PTO will not disengage #1
b dukes
McRae Ga
285 MF and 284 Farm Boss and D31 Komatsu
Haven't used the tractor in a few months. After cranking it I pushed in the clutch to put it in gear , wouldn't go in gear just grinding. Clutch was stuck. Cranked it in gear and worked the throttle and pumped the clutch at the same time. It finally broke free , but it seems the second stage is stuck and will not come free. I cranked it with the PTO in gear and cut grass for about an hour. Still stuck. Any ideas without breaking the tractor in half. The clutch , pressure plate and release bearing only has about 100 hr on it.
   / Jinma 284 PTO will not disengage #2
I guess I'd take off the side cover (Under the bracket that holds the loader bracket) and look inside.maybe adjust the clutch arms inside there to open up real wide and maybe you can break free the pto disc in there.after freeing it then readjust the arms.
2008 Isuzu NPR-HD Landscape Dump Truck (A50323)
2008 Isuzu NPR-HD...
2014 Honda Accord Sedan (A50324)
2014 Honda Accord...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2012 Wells Cargo CEW202 24ft T/A Enclosed Trailer (A50324)
2012 Wells Cargo...
2004 International 7500 T/A Roll-Off Truck (A50323)
2004 International...
1991 Peterbilt 378 T/A Dump Truck (A50323)
1991 Peterbilt 378...
