Jinma 284 Overheating
/ Jinma 284 Overheating #1
TJW
Arlington, WA
Jinma 284 LE
Hello - New to the forum.
My 284LE overheats when I am brushcutting. I run it in 2nd gear. The main issue seems to be the radiator getting grass seeds plugged in it. Also the hood seems to keep the enging pretty hot. If I run it with the hood up in the early morning, it runs at about 100C. I think I need to pressure wash the radiator again to get the crud out. I use an air compressor, but it doesn't quite do it.
It seems this wasn't engineered very well. Has anyone figured out a good modification for this or a work around??
Thanks.
/ Jinma 284 Overheating #2
If you do a search you will find a lot of discussion on overheating while mowing. Some have filters to help. Some just blow the radiator out with high pressure air. In the summer I am using plain water no antifreeze.
Harold
/ Jinma 284 Overheating #3
there is a screen that is supposed to be in front of the radiator, but stuff will get through around it. some have used household furnace filters with good success, but it must be kept clean.
Thanks. I think I'll try the furnace filter idea.
/ Jinma 284 Overheating #5
Can't see your tractor, so I'm gonna speculate that the air filter housing is in front of the radiator. Lousy place. Diesel intake suction creates negative pressure up there, and can significantly reduce air flow through the radiator. Poor little plastic fan doesn't have a chance. So I bought a section of 2" suction hose (suction hose is designed not to collapse under vacuum), connected it to the air intake hole, ran it over the radiator, over the intake manifold, and alongside the fuel tank. Sucked in nice cool air down by my left knee. Ran too cold in the winter though, had to go with a shorter section of hose routed over the exhaust manifold (to suck in warm air).
The cooling fan is supposed to be completely surrounded by the fan shroud. Adjust it and/or the radiator as required to optimize air flow.
Pressure washers and aluminum radiator fins don't mix. Stick with compressed air, even if it means taking the radiator outa the tractor.
Also, a 50/50 mix of anti-freeze and distilled water on an otherwise closed cooling system (good cap/no leaks) will raise the boiling temp. Much better than plain water.
I started using the cheap blue furnace filters myself. At 50 cents each, you don't even have to bother cleaning. Throw away and stick in another 50 center. Unfortunately, I could never find one the right size, and always ended up cutting down a larger one to fit the Jinma radiator. I don't use them anymore, since I found a heavy duty universal filter at WalMart. It's dark green in color, does not require a cardboard frame, and can very easily be cut to fit. It also can be removed for cleaning. It looks to be pressure washer safe, but I usually get mine clean enough just by taking it out and hitting it a few times on the tractor tire.
//greg//
Thanks Greg, that gives me lots of options. I should be mowing up a storm in no time.
TJ
/ Jinma 284 Overheating #7
DO NOT use a pressure washer or other high force water to clean the radiator, you will do a LOT of damage to the fins. Even a straight stream from a garden hose or air from a compressor at close range can do a considerable ammount of damage. Since the debris was sucked into the front, it would make sense to blow it out from the rear but the fan and shroud make this impossible without disassembly. About the best I have found is to use a shop vac with a soft brush attachment from the front and suck the debris out the same way it came in. You may have to carefully pick at the more stubborn pieces with a toothpick to loosen them up.
I know on mine I can feel the airflow from the fan/radiator on my right leg.
I also get debris past the removealble screen on mine and am working on this problem as well. I was thinking a finer mesh screen to replace the hole in plate type sieve screen that mine came with. I think this would also flow a little more air than the stock one, but still be reasonably easy to clean like the stock one is.
It is habit for me to scan the gauges frequently and with 70-75 degree air temp, my temp gauge runs about 80-85 while running the mower. If it creeps up toward 90, I stop and clean the filter and it goes right back down to low 80's. I run a 50/50 antifreeze mix.
/ Jinma 284 Overheating #8
If you have an air compressor then go to Harbor Freight and purchase the long (24") air gun. You can then blow out the radiator from behind and do a fairly decent job by using some gymnastic manuevers!
Thanks, I thought of that and I am looking for one.
By the way, has anyone had a problem with the little clear plastic hose collapsing between the oil filler cap and the air induction? If this was a car I would say it was the PCV system.
Mine is completely collapsed and split. Can I just replace it with vacuum line??
I've put a 100 hours on my tractor without too much work and now I am looking at dialing it in a bit. Had a problem with my fuel over the las week. Lots of crud in the bottom of the tank. Replaced the cheap plastic sediment bowl with a glass one from NAPA, I was getting air in the fuel system causing problems. Still have some crud in the tank, but it's working it's way out.
TJ
/ Jinma 284 Overheating #10
</font><font color="blue" class="small">( By the way, has anyone had a problem with the little clear plastic hose collapsing between the oil filler cap and the air induction? If this was a car I would say it was the PCV system.)</font>
There shouldn't be much vacume on that hose to cause it to collapse, unless your air filter and crancase breather filter are really clogged. As for a replacement, I would say an appropriate size vacume hose would be ok.
/ Jinma 284 Overheating #11
try running her at 1500 rpm in 1st gear..........this will bring down the temps........stroke on
Where is the crankcase breather filter??
/ Jinma 284 Overheating #13
<font color="blue">( Where is the crankcase breather filter?? )</font>
<font color="black"> It is on the right side of the engine block. There is a pipe that comes out of the engine block and bends upward. There is a can on top of this with a wingnut on top. It is part numbers 50-55 in the picture in the following link.
http://johnstractor.homestead.com/files/EngineBodyFig001.jpg
You were correct in your assesment that it is a PCV system. The slight vacume keeps an airflow through the engine. Air comes in through the breather filter and out through the hose on the oil fill cap and is burnt in the engine. This is also important to help remove fuel vapors when the engine is warm. Diesel fuel gets past the rings and dilutes the engine oil. When the engine and oil is at high temp, this fuel vaporizes in the crankcase. If not removed, these vapors can cause a crankcase explosion.
Clogged filters could also contribute to your overheating problem as you would be burning more fuel to maintain RPM while mowing. Many commercial filter assemblies and even a lot of the newer SUV airfilters have telltales on them that show when the vacume between the filter and the engine is too great and the filter needs cleaned/replaced. When my tractor was delivered, I put a "T" in that clear line and mesured the vacume there at idle and full RPM just for my info. I was contemplating putting a small vac gauge on the panel to let me know If I have clogged the filters while operating. As it is now, I check/clean the air filter whenever I have to clean the radiator. </font>
/ Jinma 284 Overheating #14
Yeh..any hose will do..I used some ole vacuum hose I had around from a old car.Others have said they noticed lower oil pressure when that hose colapsed??Don't know why but ???
OK. Here is the update. I tried all the suggestions.
I flushed the radiator, blew out all the debris in the fins, installed a furnace filter, re-routed the air intake. Installed distilled water and coolant 50/50.
I looked at the shroud alignment, looked OK. Should the fan be closer or farther away from the radiator?
Still was overheating. I am running a 4' deck and the grass is 4-5' tall.
I then removed the thermosatat, it looked "sprung", with one side popped loose. Anyway I left it out. Seemed to help a little bit.
I was running in the green rpm zone in 1st low. I could go for about 5 minutes before hitting 100C. I would then pop the hood and let it cool for a couple of minutes. The engine doesn't bog down, so I don't think it's overloaded. I got tired of this and ran with the hood up and it ran at about 90C. This was a cool day also. Something still doesn't seem right.
TJW
/ Jinma 284 Overheating #16
TJW, You may have found something with that sprung thermostat?. I recommend replacing it and keeping a thermostat in the engine. I dont think the coolant will stay in the radiator long enough to cool with out it.
The fan blade pulls air through the radiator....so it should be adjusted so the max amount of air is being drawn through the shroud.
Make sure fan belt is not loose.
Ronald
/ Jinma 284 Overheating #17
I agree with the other poster.. the thermostat is designed to keep water in the radiator long enough to let it cool down..
Soundguy
/ Jinma 284 Overheating #18
consider another opinion please. First water flowing in a radiator can be considered in laminar flow. This means most of the passages for water are in constant contact with the water. This allows good heat conduction from water to the metal, then fins, and then to the air flow from the fan and any forward motion. In an auto the air flow from forward motion becomes the primary contributor at and beyond highway speeds. No matter how fast the airflow gets, well short of high fractional mach numbers of course, the cooling just gets better and better. The same is true of the water flowing in the radiator. The water moves the fastest at the highest RPM and when the thermostat is full open. This gives the most cooling. Thermostats when full open are designed to provide the maximum flow possible. No thermostat is only a little different than a full open thermostat. The water would have to fail to contact the metal passages to cause a loss in cooling. If this was a gasoline engine I would say the over heating is either the wrong ignition timing or mixture is too lean. Perhaps combustion timing is off here.
Harold
/ Jinma 284 Overheating #19
</font><font color="blue" class="small">( Perhaps combustion timing is off here.Harold )</font>
Or maybe the coolant isn't staying in the radiator long enough to cool off !
//greg//
/ Jinma 284 Overheating #20
I don't understand what that means. Can you please explain to an old engineer how that can happen. The faster the engine turns the faster the coolant flows. The water pump empeller is a constant volume device. It moves about the same volume of water each revolution. The higher the RPM, the faster the empeller turns. The faster it turns the higher the velocity of the coolant thru the system. The coolant can be considered to be standing still and the heat flowing thru the system for calculations. The water to metal contact is constant for all coolant velocitys. the higher the coolant velocity the lower the temperature drop across the radiator for a constant heat load. The hot water enters the radiator at the bottom and exits at the top, reverse syphon. The water cools as it rises. More is better when it comes to flow across the radiator. Are you saying it is better to a point but the small increase from removing the thermostat will cause the coolant to not make contact anymore? If that was the case if you increase the RPM of the engine a little would you expect the cooling system to stop working? Would you expect better cooling if the thermostat did not open completely? Where is the special point the radiator will stop working? I have worked with hopped up engines that turned 50% faster than stock and developed 50% more power. About 1/3 the fuel pushs the piston, 1/3 goes out the exaust and1/3 out the radiator. In some cases a larger empeller in needed sometimes not. But in all cases a lot more water goes thru the radiator at a lot higher speed. far faster than removing the thermostat.
Harold
2024 Linx Trailer (A60462)
2024 Linx Trailer...
2018 Chevrolet Trax SUV (A61569)
2018 Chevrolet...
(INOP) 1997 FORD ECONOLINE VAN (A59823)
(INOP) 1997 FORD...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2017 Ford F-550 Signalier ATR 45ft Bucket Truck (A61568)
2017 Ford F-550...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
