3-Point Hitch Jinma 284 hyd lift won't stay up
   / Jinma 284 hyd lift won't stay up #1
gunnershy
Honeyville, Utah
Jinma 284
I have owned this tractor for quite a while but don't know much about tractors. I just read 'Won't stay up' post by Licking and the answers he got answered my question but he had a different brand of tractor. Sounds like I have some damaged O rings and wipers. The manuals I have are very difficult to read and I can't figure out where to start. Are there any good repair manuals for the Jinma 284? How much is the rebuild kit?
Vance
   / Jinma 284 hyd lift won't stay up #2
   / Jinma 284 hyd lift won't stay up #3
There are a few Jinma dealers that read here regularly that can answer the rebuild parts kit price question.
As for manuals, there are really none out there that are going to walk you thru the process step by step. Johns jinma website is a wonderfull resource for the Jinma 200 series tractor, and someone may have posted a step by step repair of the lift box there.
johnstractor
I can go over the basics here:
1. Remove the links between upper and lower lift arms, and the lower lift arms.
2. Drain hydraulic fluid out of lift box. The drain plug is located at the lower left corner of the rear plate on the lift box where the toplink attaches to the tractor. It looks just like a bolt, but it is not evenly spaced like the actual plate mounting bolts are. I find this is easier with the tractor raised at the front(driven up on maintenance ramps?). A funnel and a hose into a larger container is also helpfull as it is difficult to hold a container up under the drain hole.
3. Remove the bolts around the toplink attach plate and the plate itself.
4. With the plate removed, the upper lift arms will be able to be rotated up, and I believe this will allow the internal 3PH lever to rotate out of the way of the piston.
5. Remove the piston out thru the back and replace the seals on the piston.
6. Apply hydraulic oil to the seals for lube and reverse the disassembly process...
Good luck
Thanks Tommy & Ron. I will get the rebuild kit and start on this next week.
Vance
   / Jinma 284 hyd lift won't stay up #5
I had the same problem a couple months ago do I bought the kit from Tommy's Affordable and they helped me with any questions and it turned out to be an easy job!! Now my three point works like a champ! Tommy's is class A in my opinion very helpful guys!
Chris
2016 FREIGHTLINER M2 WATER TRUCK (A51247)
2016 FREIGHTLINER...
UNUSED X-STAR 70" QUICK ATTACH MANURE/SNOW PUSHER (A51247)
UNUSED X-STAR 70"...
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
2016 JOHN DEERE 8245R LOT IDENTIFIER 169 (A53084)
2016 JOHN DEERE...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
