TheSheriff
Been awhile.
I'm still researching but I thought I would post here just in case someone has seen my specific combination of symptoms and what the fix turned out to be. I'm leaning toward injectors or governor? but not yet sure how I'd proceed with either.
History. 2010 Jinma 284, 450ish hours. Used regularly, but due to health issues, only used 5-6 times for very short periods last 2-years. Maintained fresh diesel with conditioner. I had not used it for last 4-5 months due to flat rear tire. Should have turned off the fuel but didn't. No history of engine oil or pump oil use, nor either "Climbing" the dipstick.
So I needed to back out of the carport to remove the box blade to more easily jack up the rear. Pulled the dipstick on the F-pump and and a very thin liquid (Diesel I assume) poured from the hole; perhaps an ounce. Much thinner than the compressor oil I have always used. Drained and refilled.
Started tractor, it blew a bit of smoke and immediately over-revved. Pulled the kill cable. Repeat several times. Throttle cables/arms appear to be moving fully and normally. Lubed with WD. Started again and manipulated the kill cable to maintain safe RPM. After running perhaps 5-6 minutes and jockeying the throttle (Via the kill cable) it idled normally. Backed it out and left it running while I disconnected the BB. After running 15-minutes, it went the opposite direction and idle dropped too low and stalled. It ran fine and would not stall while driving, just didn't want to idle. It would also re-start just fine, then again run fine, but stall if left at normal idle.
Hoping I had broke something free, I started it next day. The same exact thing. Over-revved, manipulate, warm up, idle normally and then runs great but wants to stall on idle. Thought I would try once more the next day. Same exact thing EXCEPT it never went to normal idle after warm up. Whatever was "breaking free" before was no longer. Tried again, same thing.
Any ideas appreciated.
