Jinma 284 clutch questions???
/ Jinma 284 clutch questions??? #1
Dre0256
Cambridge, Md
Jinma 284
I have a 2004 jm284 with a Y385 motor. The clutch is on its last leg. I researched and see a 8" & 9" clutch. Just trying to figure out which one I need. Also besides the clutch do I need anything? I see I need to split the tractor in half, any tips or suggestions? Thanks in advance.
/ Jinma 284 clutch questions??? #2
Comtact affordable he will confirm what part you need.
As for splitting, smooth concrete floor, jacks, jackstands and blocks...
How are you determining that the clutch is failing? Have you confirmed its adjustment. I have had a linkage problem lead me to believe the clutch is bad. There is a lever outside on the left side that fits over a pivot that passes thru the side of the case the pin that keeps the lever on the pivot went bad and allowed a ton of slop to enter the equation...
/ Jinma 284 clutch questions??? #3
As RonMar said, Affordable is your best bet and the other tips as well
Use a trolly jack on one end or the other so you can move the tractor forward or back. Block the engine so it can't roll when you split the tractor, it's a wakeup when you separate it and the engine rocks over
Throwout bearing, pilot bearing, think there was a gasket of sorts between the bellhousing and the engine, check your rear engine and trans seals as well as the roll pin for the throwout bearing fork. I replaced mine with a gr8 bolt.
Now's the time to run a tap thru the bolt holes and replace the Chinese junk bolts with longer (if you have the depth, mine did) with 10.9 bolts and blue Loctite, lose the lockwashers.
..........Mike
/ Jinma 284 clutch questions??? #4
We can help you with anything you may need, we also have a splined Clutch alignment tool we give to you with a Complete clutch assembly.Most tractors have the 8" Assembly but there were several that had the 9" also.
I recommend going ahead and splitting the tractor, determine the correct size they are expensive to ship back and forth,If it need a clutch I always recommend the complete clutch assembly with PTO Disc, New release bearing new Pilot bearing
We keep them both in stock so normal shipping is 3-4 days after you place the order
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
979-86504002
/ Jinma 284 clutch questions??? #5
Re: Chinese Tractors
There were discussions earlier today on Chinese made tractors. Couldn't figure out how to post on that particular thread?
I have a Tractor made by Feidong (Shan Dong)
2003 Kama KM454
Name Plate stamped: Model# 395T
Does anyone have any suggestions or outlets for obtaining parts, owner and/or service manuals for this tractor?
Thanks!
