Oil & Fuel Jinma 284 and Mityvac Oil Evacuation
   / Jinma 284 and Mityvac Oil Evacuation #1
Smalljobs
Massachusetts
Jinma 284
I picked up one of the vacuum oil evacuators to use on my VW Passat TDI, my Jinma 284, Saab, and other machines. There are plenty of videos for the VW diesel so I knew in advance that I could remove all the oil from the dipstick hole.
I had trouble with the Jinma and could not insert the thinnest plastic tube to bottom out in the sump because it got hung up near the bottom of the external dipstick tube. I picked up some thin wall brass tubing from a hobby shop and the tubing diameter was the same as the dipstick outside diameter. So far so good.
By using the brass tube together with the plastic tubing I was able to insert the assembly until it bottomed out. Then I evacuated all the oil. To be sure, I removed the sump plug and at least a half pint or more came out, proving the extraction tube, while bottomed out, was not at the lowest point in the sump.
Has anyone else had this happen? Is there a solution other than returning to using the standard oil drain plug?
   / Jinma 284 and Mityvac Oil Evacuation #2
I have drilled and tapped drain plugs and added a length of copper tubing up the side of the engine. Size to suit.
You may also be able to drill and tap a cast sump at the lowest spot at the rear.
   / Jinma 284 and Mityvac Oil Evacuation #3
Can you fit a Fumoto?
You still drain down, but easily.
   / Jinma 284 and Mityvac Oil Evacuation #4
My DF has a sump drain on both sides due to the two low points caused by the front drive shaft. I would want any crud that settled here to be drained out so have no problems pulling these plugs. My plugs are very easy to get to, maybe the Jinma is different.
Cleat
   / Jinma 284 and Mityvac Oil Evacuation #5
Or replace the drain bolt with a banjo bolt and plumb a line from the banjo up alongside the dipstick where you can have easy access to connect the vac pump... Many marine applications do it this way.
Thank you all for the help.
2014 AMADAS SPC-6-36 LOT NUMBER 211 (A53084)
2014 AMADAS...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
2024 High Country Cargo 6x12 Enclosed Trailer, VIN # 7FWBE1217R1035595 (A51572)
2024 High Country...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
