Oil & Fuel Jinma 254 Oil Filters
   / Jinma 254 Oil Filters #1
mitchash
Greene, NY
Mahindra MAX 28XL, Jinma 254 (Sold)
I am looking to change the oil and filters on my Jinma 254. Where are the best places to buy them? Are there NAPA or other after market filters that fit? Mine has, Engine Oil filter part # JX0707 Hyd. Filter # JX0811A and fuel filter # HECX0706. Thanks, Ash
   / Jinma 254 Oil Filters #2
Which engine? If it's the YangDong Y85 series, you can use this list to start from:
Oil Filter - NAPA= 1516 ($6) Purolator= PL20195 ($6)
Fuel Filter - NAPA= 3195 ($11) Purolator= F50284 ($10)
Air Filter - NAPA= 2276 ($24) Purolator= A42019 ($15)
Prices are probably a bit outdated though
//greg//
   / Jinma 254 Oil Filters #3
Here are the US equivalent filters I use on my tractor which is a 2003 model. Give them a try. You can cross them over to your favorite brand.
Air= Purulator A42019
Oil= Fram PH3950 Size of filter is different but threads and O-ring are the same. All that matters.
Fuel= Fram P6503
My tractor did not come with a spin on hydro filter/strainer. I added one but its aftermarket and my filter is on the return side and is not the same so no help on that one. I do know you do not want a filter, you want a hydraulic stainer since its on the suction side and I think the recommendation is 10 micron but not sure.
Chris
I went to my local NAPA dealer and they crossed the fuel filter with there 3195 and engine oil filter 1315. They couldn't cross the hyd filter though.
   / Jinma 254 Oil Filters #5
Try a Napa 1553 30 micron for the hydraulic ;)
   / Jinma 254 Oil Filters #6
Not if it's on the suction side - he'll risk cavitating (starving ) the pump. Some folks recommend 125-150 micron. I found I have acceptable cold weather flow with 80 micron, but I wouldn't go any smaller. If it's on the pressure side, that's a different story.
//greg//
   / Jinma 254 Oil Filters #7
So give him the numbers of the filters Greg :mad:-- this is the filter I run when above freezing and it has worked fine for a couple of years now -- it is cheap enough that I throw it away in the fall . If you are afraid of it causing a problem or want to run larger micron screen type filter, Donaldson make a 1" - 12 thread wire mesh 150 micron filter that fits and costs about $25 CDN here. It is a Donaldson P25550274. Napa also have a 1614 that is more wide open and fits on my 2006 284 -- it too is an expensive filter. By the way on this debate in the past, nobody seems to be too sure what the micron rating of the original filter is :eek: I have never measured my return hydraulic flow to see if it is "acceptable" but I did a lot of research to find filters that fit and oil that met the specs outlined by some "experts" only to find it based on opinion not reality.
   / Jinma 254 Oil Filters #8
So give him the numbers of the filters Greg.
Ain't none, it's 80x80 brass mesh. I buy it in bulk and make replacements myself. But regardless of the form it takes, 80 microns is 80 microns
//greg//
   / Jinma 254 Oil Filters #9
How often have you changed your air filter? I have just been blowing mine out with compressed air. Richard
   / Jinma 254 Oil Filters #10
2014 MACK CXU (PINNACLE) (A50854)
2014 MACK CXU...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
CHALLENGER VACUUM PUMPS (3) (A50854)
CHALLENGER VACUUM...
2007 Ford F-150 Pickup Truck (A50323)
2007 Ford F-150...
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2016 HINO 268A BOX TRUCK (A51219)
2016 HINO 268A BOX...
