Jinma 254 gear change while moving
   / Jinma 254 gear change while moving #1
mickstanz
WA, Australia
Jinma 254
Hey guys,
I have a question regarding shifting gears on my Jinma 254 while it's moving. I can't seem to get a smooth gear change. I have tried double clutching, changing at different RPMs etc but it's still not smooth. Is it even designed to change gears while moving? I would have thought so. I'm a large scale crop farmer so I drive heavy duty machinery all day, not use to the size or build quality of the little Jinma. Thanks for any ideas you may have.
I should note - the clutch feels and acts perfectly normal in every other instance so I don't believe that's my issue.
   / Jinma 254 gear change while moving #2
Generally I always am stopped when changing gears. It's not a syncro, just a crash box. I have done it but not too often. Usually in hi range 2-3 or 3-4. Low range never necessary.
That's what I've been doing as well as it didn't like shifting while on the move. I only occasionally shift from 2 to 3 in high range, and only if I'm going a long distance. It takes off in 2nd High no problem but 3rd High you would have to ride the clutch too much.
Low range isn't a problem, I find that 3 Low does most things I want, 1 and 2 are almost too low.
My Jinma has High/Low with 3 speed gearbox. Shuttle shift F/R.
Thanks for your input mate
   / Jinma 254 gear change while moving #4
The transmission and gear case gears are all spur cut. They are not designed to shift-on-the-fly. There are no synchros.
However, not saying it can't be done with a lot of practice.
Thanks for clearing that up
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
550 gal Gravity Flow Fuel Tank with Stand (A50515)
550 gal Gravity...
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
UNUSED FUTURE GALVANIZED STEEL SITE FENCE (A51244)
UNUSED FUTURE...
