Jinma 254 gear change while moving
   / Jinma 254 gear change while moving #1
mickstanz
WA, Australia
Jinma 254
Hey guys,
I have a question regarding shifting gears on my Jinma 254 while it's moving. I can't seem to get a smooth gear change. I have tried double clutching, changing at different RPMs etc but it's still not smooth. Is it even designed to change gears while moving? I would have thought so. I'm a large scale crop farmer so I drive heavy duty machinery all day, not use to the size or build quality of the little Jinma. Thanks for any ideas you may have.
I should note - the clutch feels and acts perfectly normal in every other instance so I don't believe that's my issue.
   / Jinma 254 gear change while moving #2
Generally I always am stopped when changing gears. It's not a syncro, just a crash box. I have done it but not too often. Usually in hi range 2-3 or 3-4. Low range never necessary.
That's what I've been doing as well as it didn't like shifting while on the move. I only occasionally shift from 2 to 3 in high range, and only if I'm going a long distance. It takes off in 2nd High no problem but 3rd High you would have to ride the clutch too much.
Low range isn't a problem, I find that 3 Low does most things I want, 1 and 2 are almost too low.
My Jinma has High/Low with 3 speed gearbox. Shuttle shift F/R.
Thanks for your input mate
   / Jinma 254 gear change while moving #4
The transmission and gear case gears are all spur cut. They are not designed to shift-on-the-fly. There are no synchros.
However, not saying it can't be done with a lot of practice.
Thanks for clearing that up
John Deere MX5 3pt 60" Rotary Mower (A50774)
John Deere MX5 3pt...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51243)
2017 CASE IH 580...
2008 KALMER 4X2 SPOTTER TRUCK (A51243)
2008 KALMER 4X2...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51243)
UNUSED FUTURE BOX...
Noble 8 Row Cultivator (A50514)
Noble 8 Row...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
