Jinma 254 electrical problem!!!
/ Jinma 254 electrical problem!!! #11
Cool!
At least you can start and use it without blowing a fuse.
Quickest check to separate wire problem from glowplug in the glowplug circuit, is to lift the green wire that connects to the bussbar that ties all 3 plugs together, and see if it still blows a fuse. If it does, the problem is in the glowplug wiring or the keyswitch. If it dosn't, the issue is in the 3 plugs. If you have a volt/ohm meter, you can lift the bar that ties all 3 glowplug power input terminals together, and measure the resistance of each plug individually to ground. This should help identify a single bad plug...
Since you said it is blowing the main fuse and not the glowplug fuse(both 30A), I am thinking it is probably a problem with the wiring or keyswitch...
The attached schematic I drew from my 05 284's wiring may be of use...
Thanks for the wiring diagram, very useful.
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
1998 Chevrolet Step Van Food Service Truck (A59230)
1998 Chevrolet...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2020 Broyhill Load and Pack TD3.6 Mini Articulated Garbage Truck (A59230)
2020 Broyhill Load...
Deere 335P (A53317)
Deere 335P (A53317)
