Jinma 254 Agracat
   / Jinma 254 Agracat #1
Stiffler63
DeWitt,Ar
Looking
I purchased a 254 recently and it has been ran down. The radiator is cracked. The cylinders leak on the FEL as well as the hydro gasket under the rear seat. The oil filter looks to have been on for years and is beat to ****. Front bucket is bent. Alternator does not charge no lights work. It also is a tacless model I would like to add one. Iv been trying to remove the steering wheel with no luck.Any help or suggestion you guys have. I am changing all fluids and filters over the next few weeks. IMG_1900.JPGIMG_1898.JPGIMG_1962.JPGIMG_1963.JPGIMG_1964.JPGIMG_1965.JPGIMG_1966.JPG
   / Jinma 254 Agracat #2
There are a number of Jinma owners on here, hopefully they will chime in. Is there at least an hour meter?
   / Jinma 254 Agracat
I finished tearing it apart for the most part. I cleaned the engine and pulled all the unused wires and the fuse block will upgrade them.
   / Jinma 254 Agracat
All cleaned up. Bottom picture is of the gasket i have to replace.
   / Jinma 254 Agracat #6
Looks a lot better. What did you clean it with, all the old grease and grime is gone.
Cleat
   / Jinma 254 Agracat
Oreillys has purple power for 6$ per 2 gallons. i use it for everything out side even cleans siding.
   / Jinma 254 Agracat #8
   / Jinma 254 Agracat
I will be contacting you tomorrow hopefully. I need a few gaskets specifically the one for the rear hydraulic housing under the seat between the 3point top arms and the pto and hopefully you have a exploded view of this. Also it did not come with a tach when new how can I add this? I also drained the front driveline in 3 places is there a place to a gear oil on the outer drives or does it all run from the axle tubes?
   / Jinma 254 Agracat
Will Chevron 1000 THF be ok in the hydro system
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
JOHN DEERE 661R LOT NUMBER 106 (A53084)
JOHN DEERE 661R...
Bushog 6ft Disk Mower (A51573)
Bushog 6ft Disk...
378668 (A51573)
378668 (A51573)
2019 KOMATSU  D65 PXI 18 (A52472)
2019 KOMATSU D65...
