Jinma 254 4wd
/ Jinma 254 4wd #12
Shift lump on the shifter is probably broken. You'll have to take the top off the shifter box to check it. If if is broken, a replacement isn't expensive, but you absolutely MUST find the broken off piece in your transmission and remove it so it doesn't get into the gears and trash them.
/ Jinma 254 4wd #13
There's a "finger" at the very bottom of the shift lever. It fits in the slot formed by a sliding "fork". If you've got first and reverse, the finger is probably still good. More likely a fork or forks for 2nd/3rd has slid out of reach of the fork. Either way, undo the bolts holding the cover plate to the housing. Make sure you remember which gear position the lever was in before removing. The whole thing - plate and levers - can be pulled straight up. At that point you can get a good look at both the shift lever finger and the sliding forks.
//greg//
(INOP) 2014 DODGE CHARGER (A59823)
(INOP) 2014 DODGE...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
2019 John Deere 460E Articulated Dump Truck (A60352)
2019 John Deere...
2024 GMC Seirra Elevation Crew Cab 4X4 Pick-Up Truck (A60352)
2024 GMC Seirra...
159115 (A60430)
159115 (A60430)
