Jinma 2240 - OIL LEAK
   / Jinma 2240 - OIL LEAK #1
mcsor879
Jinma 2240
I've watched this forum for a while, seen the vast knowledge that you all have on here, so I'm hoping someone can help me. My tractor has only 40 hours on it and until this leak, haven't had a bit of trouble. I just identified the part from one of the books as the "respirator." When I start the tractor, oil just pours out from the bottom of the respirator. From the respirator cannister, there is a solid tube that connects to the block and a small open ended tube, approximately 1 1/2" long. It almost looks as though a hose would be connected to this, but after checking thoroughly, I didn't find where this might be connected to.
What function does the respirator have and why would it be leaking? /forums/images/graemlins/confused.gif
   / Jinma 2240 - OIL LEAK #2
That part is also known as a crankcase breather. It's function is to allow air into the crankcase which is then sucked out through the hose attached to the oil filler cap. this hose connects to the intake manifold and the vacume on the intake manifold keeps a flow of air through the crankcase. This keeps unburnt diesel fumes in the crankcase from building up to the point where they could ignite(crankcase explosion).
As I said air should go in, oil should not come out. How much oil is showing on the dipstick? The only failure that I could think of that might raise the oil level is if the hydraulic pump shaft seal failed and the pump is adding hydraulic fluid to the front gearcase/engine raising the level above the point where the Respirator is attached to the block. I guess a block/head/gasket failure could potentially add coolant to the oil and raise it's level but the oil comming out would look pretty nasty and you didn't mention that.
   / Jinma 2240 - OIL LEAK #3
It's a simple crankcase breather, and is probably dirty and/or full of water. If it's foaming out milky stuff, it's definitely taken on water. Remove the top, remove the filter element. Clean element/housing/top, dry everything, then reassemble. See if that resolves your issue.
//greg//
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A53473)
2012 RAM 5500...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
(2) 275 GALLON POLY TANKS W/ CAGES (A51248)
(2) 275 GALLON...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
