Jinma 224 Hydraulic pump question
   / Jinma 224 Hydraulic pump question #1
ohiobenz
Amish Country Ohio
Jinma 224
Has anyone retrofitted a better/more volume pump onto this little tractor?
I want to add a 3pt log splitter and a FEL later on.
   / Jinma 224 Hydraulic pump question #2
I have a new pump for a YW-6 Jinma Backhoe. It mounts on the rear of the tractor, not sure which models. I mounted the Hoe on my Branson and didn't use the pump. I will make a good deal on it if you are interested.
   / Jinma 224 Hydraulic pump question #3
I'm not sure which pump you have now,since you don't have power steering,the Jinma 254/284 tractors come with a 314 pump which will run a log splitter and a FEL,if you have the Y380 engine I assume you have that pump now,check it out the # is stamped on the pump
Tommy
Affordable Tractor Sales
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
Tommy, I believe its the 310 pump since its a 224 with the TY290 engine.
I dont know the specs of the current pump. Whats the price of the 314 pump? Is it a direct retrofit? Is it a single stage or 2 stage pump?
wasnt thinking about going that route... but maybe you can convince me??
   / Jinma 224 Hydraulic pump question #6
I have a 254 that is a 2003 model and I run a FEL and my home made log splitter with zero issues and 550 hours.
Chris
   / Jinma 224 Hydraulic pump question #8
Hi Ohio Benz:
regarding the backhoe pump. You will need to make sure youre tractor is equipped with the slotted drive gear prior to buying a pump for the rear end. The 4 bolt flange above the PTO comes off and there is a shaft with a ~ 1/4" wide slot cut through center, that is the correct shaft. others do not have the 1/4" slot and that shaft then would have to be replaced (requires some transmission disassembly but not real difficult), I think parts would be some place close to a hundred bucks if I remember right if you have to replace this shaft & bearings /seals. The pump would bolt in place of that 4 bolt flange and you have to have the PTO engaged to run the pump. I have a 384 with backhoe (JW03)
live in Jeromesville Ohio
Mark M
   / Jinma 224 Hydraulic pump question #9
stimw, I am interested in the gear pump if you still have it for sale.
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
New Land Honor Skidloader Trailer Mover (A50774)
New Land Honor...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2012 CHREVOLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHREVOLET...
