Jinma 224 Hydraulic pump question
/ Jinma 224 Hydraulic pump question #1
ohiobenz
Amish Country Ohio
Jinma 224
Has anyone retrofitted a better/more volume pump onto this little tractor?
I want to add a 3pt log splitter and a FEL later on.
/ Jinma 224 Hydraulic pump question #2
I have a new pump for a YW-6 Jinma Backhoe. It mounts on the rear of the tractor, not sure which models. I mounted the Hoe on my Branson and didn't use the pump. I will make a good deal on it if you are interested.
/ Jinma 224 Hydraulic pump question #3
I'm not sure which pump you have now,since you don't have power steering,the Jinma 254/284 tractors come with a 314 pump which will run a log splitter and a FEL,if you have the Y380 engine I assume you have that pump now,check it out the # is stamped on the pump
Tommy
Affordable Tractor Sales
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
Tommy, I believe its the 310 pump since its a 224 with the TY290 engine.
I dont know the specs of the current pump. Whats the price of the 314 pump? Is it a direct retrofit? Is it a single stage or 2 stage pump?
wasnt thinking about going that route... but maybe you can convince me??
/ Jinma 224 Hydraulic pump question #6
I have a 254 that is a 2003 model and I run a FEL and my home made log splitter with zero issues and 550 hours.
Chris
/ Jinma 224 Hydraulic pump question #8
Hi Ohio Benz:
regarding the backhoe pump. You will need to make sure youre tractor is equipped with the slotted drive gear prior to buying a pump for the rear end. The 4 bolt flange above the PTO comes off and there is a shaft with a ~ 1/4" wide slot cut through center, that is the correct shaft. others do not have the 1/4" slot and that shaft then would have to be replaced (requires some transmission disassembly but not real difficult), I think parts would be some place close to a hundred bucks if I remember right if you have to replace this shaft & bearings /seals. The pump would bolt in place of that 4 bolt flange and you have to have the PTO engaged to run the pump. I have a 384 with backhoe (JW03)
live in Jeromesville Ohio
Mark M
/ Jinma 224 Hydraulic pump question #9
stimw, I am interested in the gear pump if you still have it for sale.
2024 John Deere 333G Tack Loader (A63111)
2024 John Deere...
OXBO CP100 - 1R SWEET CORN HARVESTER (A63291)
OXBO CP100 - 1R...
iDrive TDS-2010H...
2022 New Holland SP310F Sprayer (A63111)
2022 New Holland...
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
