3-Point Hitch Jinma 224 3 point hitch control very stiff
   / Jinma 224 3 point hitch control very stiff #1
JeffReh
Jinma 224
The control lever on my 3 point control is extremely stiff and hard to move. I see nothing externally to lube that might make it easier. Any ideas?
   / Jinma 224 3 point hitch control very stiff #2
Jeff,
On my 304, the TPH control levers each have a thumbscrew and friction washers to make them as stiff or as sloppy as you like. Well, actually they don't work all that well and I've had to modify them a bit, but that's the concept. Does yours have anything like that?
Rich
   / Jinma 224 3 point hitch control very stiff #3
Hey there, on my 204 i removed the control lever housing and found that the little bearing/locator ball was all smashed up, you will know what i mean when you see it. A quick trip to the hardware store and 37 cents later it was fixed, oh and about a hour of labor also
   / Jinma 224 3 point hitch control very stiff #4
I fought with mine for quite some time, every time I had the valve off the tractor, it would work as smooth as silk. Finally (duh) i realized that when I torqued it down, it became tight to operate. Evidently, the machined surfaces are not flat? I snugged it down, with some blue loctite on the bolts, and it has worked great ever since.
Swict 78" Bucket (A50121)
Swict 78" Bucket...
Polaris Side by Side (A50324)
Polaris Side by...
2002 KENWORTH W900 TRI AXLE (A52472)
2002 KENWORTH W900...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
KJ 10' Galvalume Corrugated Steel Panals (A50121)
KJ 10' Galvalume...
