3-Point Hitch Jinma 224 3 point hitch control very stiff
   / Jinma 224 3 point hitch control very stiff #1
JeffReh
Jinma 224
The control lever on my 3 point control is extremely stiff and hard to move. I see nothing externally to lube that might make it easier. Any ideas?
   / Jinma 224 3 point hitch control very stiff #2
Jeff,
On my 304, the TPH control levers each have a thumbscrew and friction washers to make them as stiff or as sloppy as you like. Well, actually they don't work all that well and I've had to modify them a bit, but that's the concept. Does yours have anything like that?
Rich
   / Jinma 224 3 point hitch control very stiff #3
Hey there, on my 204 i removed the control lever housing and found that the little bearing/locator ball was all smashed up, you will know what i mean when you see it. A quick trip to the hardware store and 37 cents later it was fixed, oh and about a hour of labor also
   / Jinma 224 3 point hitch control very stiff #4
I fought with mine for quite some time, every time I had the valve off the tractor, it would work as smooth as silk. Finally (duh) i realized that when I torqued it down, it became tight to operate. Evidently, the machined surfaces are not flat? I snugged it down, with some blue loctite on the bolts, and it has worked great ever since.
2013 Vermeer V800G T/A Towable Vacuum Trailer (A50322)
2013 Vermeer V800G...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
2016 Ford Escape SE 4WD SUV (A50324)
2016 Ford Escape...
Informational Lot - Financing (A52748)
Informational Lot...
