Jinma 204 shifter problem
   / Jinma 204 shifter problem #1
RandyS
CT and upstate NY
Jinma 204, Mahindra 2816, Prowler mini skidsteer
My partner was using the tractor today and went to shift from reverse to 1st and nothing. The shift lever just flops around. Any suggestions?
Thank you.
   / Jinma 204 shifter problem #2
Well,,would look at parts manual and see how thats all connected,,and probably take cover off trans where shifter goes down in and take it from there,,,probably just a pin,,or something like that that broke or worked out,,,shouldn't be a big deal,,,but who knows till you look a little,,,thingy
   / Jinma 204 shifter problem #3
Look at the shifter forks/rails/detents and see what came loose.. sometimes set screws holding forks work out..
Soundguy
   / Jinma 204 shifter problem #4
Thank you.
Is that 204 shuttle equipped? or is Reverse on the regular gear shift lever?
//greg//
   / Jinma 204 shifter problem #5
It could be a broken shift lever or a broken shift fork,take the top off of the transmission and you should see the problem,we will have the parts in stock to repair it.Also if it is a broken shift fork,make sure you get the broken piece out of the transmission so that it cannot get in the gears.We are open on Sat until one if you need any help 979-865-4002
Tommy
Affordable Tractor Sales
Greg, it's not a shuttle.
Looks like the shifter lever is in 2 pieces.
Thank you all for the help.
PALLET OF DRAINS / DRAIN GATES (A51244)
PALLET OF DRAINS /...
2008 Ford F-350 Altec Service Truck (A50323)
2008 Ford F-350...
Land Honor Quick Attach Accumulator Grapple (A50514)
Land Honor Quick...
2003 Club Car Electric Cart (A50324)
2003 Club Car...
Woods F21D Zero Turn Mower (A50514)
Woods F21D Zero...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
