Jinma 204 Fuel Gauge
   / Jinma 204 Fuel Gauge #1
Catch95
Australia
Jinma 204
I've been having all the electrical problems encountered by many other owners. Gauges intermittent, now not working at all. I've been through loads of the old posts here which all say the same thing about bad grounds etc. I have pulled the cluster (older style), cleaned every terminal I can, redone connections behind the fuses, run a fresh ground etc. Spent hours on it, but still no joy.
Because its summer here in Australia and hot, I couldn't live without a temp gauge, so as I posted here when talking about putting in a new radiator and doing the head gasket, I put in a separate mechanical temp gauge. Readings are spot on when checked with a probe thermometer.
My fuel gauge is pegged hard right with the power on, back to zero when the switch is off. Suggests a short, so I've cleaned the connections on the wires at the sender on the fuel tank etc. Even pulled the float to check it wasn't stuck.
My suspicion is that it could be in the circuit board wiring but I can't really afford a new cluster.
Can anyone confirm if I can put in one of the old style single Jinma fuel gauges and wire it back to the existing sender? Are they compatible?
Thanks
Mark
   / Jinma 204 Fuel Gauge #2
Old post, but did you ever get your instruments working? When I pulled my fuel float, I thought it might be pretty easy for the sender to get aligned wrong. If the sender was turned too far in the "full" direction when reinstalled, that might be the cause of your fuel gauge being pegged at full.
- Rick
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
