Oil & Fuel Jinma 204 fuel filter
   / Jinma 204 fuel filter #1
rider10099
Oregon
Jinma 204
I have read about the napa fuel filter for the Jinma - but seems that it comes with a note that threads may have to be extended - new to me - how would you do it?
Cheers
rider
   / Jinma 204 fuel filter #2
I have a 204 and I replaced the fuel filter at 100 hrs. Went on with no modifications. I will take a look today at the NAPA # and let you know. I purchased mine in 2004 and currently have about 360 hrs. I assume you have the 3cyl rather than the 2cyl.
No mine is the 2 cyl.
   / Jinma 204 fuel filter #4
You might be thinking of the oil filter. The fuel filter I use on my 284 goes on without issue. The stock oil filter has a top that is domed where the threaded hole is. The domestic filter that I replaced it with is dished in where the threaded hole is and requires a longer thread to reach and engage properly. On the oil filter base/holder, the threaded pipe is held in place with a locknut. By loosening this locknut you can screw the threaded pipe out a bit to insure complete engagement with the filter, then re-tighten the locknut. I don't recall having to do this on the fuel filter, just on the oil filter.
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
20305 (A51694)
20305 (A51694)
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
LOT LOCATIONS (A53426)
