Jinma 204 fluid replacement
/ Jinma 204 fluid replacement #1
claxton2x2
Flat Rock, AL
Jinma 204
new to site....... I have a Jinma 204 and was wondering if Super Tech Heavy Duty Tractor Hydraulic and Transmission Fluid was safe to use as a replacement. Thanks!
/ Jinma 204 fluid replacement #2
Nope, that's for single sump tractors. Your Jinma is a dual sump. It needs gear oil in the gear housings (front & rear diff, transmission, mid-connect box) and hydraulic fluid in the hydraulic sump (between rear diff housing and operator seat). Most folks go with 80W90 gear oil and AW32 hydraulic fluid.
//greg//
greg_g, thanks for the fast response! I am new to the forum and new to owning a tractor so I forsee a lot of future question. Thanks again for your help.
Thanks Mike! Mine doesn't have the FEL, put I have a finish mower, bushhog, blade & tiller. My tractor has the turf tires.
/ Jinma 204 fluid replacement #6
I wish I had the turf tires for mine, the ones I have on it tear the lawn to bits in the spring and fall when the grass is soft.
I use mine, not much mind you, in the woods, clearing snow and other odd things around. I've got a backhoe, which is not used too much but when you need it, it's better than a shovel ,
I made a scarifier for it, since I took this pic I added a drop down blade in front of the teeth so I don't have to take it off and put the back blade on when i want to level what I tore up
Only problem I've had was at 100 hours I had to split it, the cam bearing on one end was put in backwards so there was no lube oil going to the top end, tore the rocker shaft, arms all to bits.
I replaced the ignition switch as the factory one was flakey and added a few relays to control the glow plugs as well as the lights I added.
Check your air intake hose, the one going from the breather to the manifold. Mine made a sharp 90 deg turn and was starting to tear which would let dirt in so I made a steel tube bend which allowed me to use a straight piece of silicone rad hose.
.....Mike
Thanks mrmikey, great pics! I will check the air intake hose like you suggested. Thanks again!
Does anyone have pics of all the locations to drain & fill your fluids? Thanks!
/ Jinma 204 fluid replacement #9
Also new to site. I have a few questions as well. I have to drain hydraulic sump and gearbox. Is the only fill for the gearbox the red bolt with the dipstick. Does this fill transfer case too?
Kubota SVL95-2S (A64126)
Kubota SVL95-2S...
John Deere 1023E (A62177)
John Deere 1023E...
1990 FRUEHAUF 53' DRY VAN TRAILER (A65054)
1990 FRUEHAUF 53'...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
