Jima 304 questions
   / Jima 304 questions #1
Momboy007
San Diego
Jinma 304
Hello All again,
Another Newbie question. I have been reading the posts and saying that the hydraulics will not work if the PTO is engaged, Is this how I read this? How do I raise and lower my bush hog if this is the case, also, can I use my 3 pt. hitch and loader at the same time?
Thanks and sorry for the silly questions
Rick
   / Jima 304 questions #2
The PTO does not stop the hydraulic's, you can use the 3 PTH and FEL at the same time. The only Chinese tractor I know of that the hydraulic's quit is when you push the clutch all they way down, thats on a Kama and TS not on a Jinma
   / Jima 304 questions #3
I have a KAMA 554. The hydraulics do not quit when you push the clutch in. The hydraulic pump is engine mounted.
   / Jima 304 questions #4
Re: Jima 304 questions *DELETED* *DELETED*
Post deleted by greg_g
   / Jima 304 questions #5
For almsot 2 years, we have imported the KM with engine mounted hydraulic pumps (couldn't get both engine pump and remotes till then). The TS has been rear mounted all long. It is very easy to get in the habit of using the 2 stages of the clutch properly and it creates no problems in use. The drive for the rear mounted pumps has proven to be very reliable. while we have seen a couple of drive gears on the engine driven pumps fail on Jinma 200 series (not many but a couple). It also relieves the engine of the load of the hydraulic pump during starting if the clutch is fully depressed. I have had no user complaints about the rear pump on the early KM or on the TS series.
BOX OF SCHUMACHER 6A BATTERY CHARGERS (A51248)
BOX OF SCHUMACHER...
2025 Mower King SSECAG-Y (A50123)
2025 Mower King...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53473)
UNVERFERTH 330 -...
