JIC 37 degree seals
   / JIC 37 degree seals #2
The hydraulic shop I go to has them, but I have never used them. And by the look of the dust on the packages not many people who go there use them either.
I have used allot of the JIC fittings and have not had a leak yet. Maybe if you had a fitting that got connected and disconnected frequently, they may be of value as the sealing surfaces of the fittings would get scored over time.
   / JIC 37 degree seals #3
The 37 degree fittings are for aircraft hydraulics. that is why the dust on the packages. They did not want people to mix aircraft and standard run-of-the-mill hardware so they made a special (read expensive) fitting just for airplanes. They will work the same just will not be compatible with most. I suppose that if you had a good supply of the aluminum fittings that you could be consistent , but connecting hoses and everything--I am sure the end result would be more.
They may have other applications too, but that is all that you are supposed to use in aircraft--at least that is what they taught when I got my A&P.
Mike in Warsaw
Ingersoll Rand 185 Towable Diesel Air Compressor (A49461)
Ingersoll Rand 185...
50 CAT 5 TOOTH EXCAVATOR BUCKET (A50854)
50 CAT 5 TOOTH...
2022 RAM 2500 (A50854)
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
