Jezebel is BLEEDING!!!!!!!!!!!!!!
   / Jezebel is BLEEDING!!!!!!!!!!!!!! #1
JayinNH
Raymond ,New Hampshire
L3010HST (Jezebel)
I did some work yesterday ripping up some stumps and doing some rough grading. I noticed a steady steam of hydraulic fluid leaking out of the FEL control box.I called MB tractor where I had purchased her on my cell phone around 7:30 this morning. I let them know that this problem occured the first day I got the machine. I recieved a call at 9:00 saying that they were on site and replacing the entire unit. I'm happy about their response time but am wondering if this has happened to anyone else who owns a L3010HST or similar tractor? Is it possible that I'm overworking the tractor? I haven't taken the tractor over 2000 RPM's.
Jason
   / Jezebel is BLEEDING!!!!!!!!!!!!!! #2
Jason,
Don't know what others are experiencing, but my B7500 hasn't dripped a drop anywhere. I do get a little bit of dripping when I connect/disconnect/reconnect the hydraulic fittings for the FEL, but it's just a few drops that I can clean up pretty easily.
The GlueGuy
Glueguy,
MB tractor replaced the entire FEL control box so maybe the box was faulty. I lost a good deal of fluid this time. The first time it happened was about 3 hours into the intial break in the fist day I had it. I hope she's ok.
Jason
   / Jezebel is BLEEDING!!!!!!!!!!!!!! #5
Jason, sounds to me like you just got a defective control valve. All manufacturers have a flaw get by once in awhile, so I don't get upset if they correct or replace it. I doubt that it was caused by anything you did. When I bought a new '95 B7100, the FEL cylinders were defective (slowly lowered the FEL even with the engine running) and they were all 4 replaced under warranty and no more problems.
Bird
Pete,
They replaced the control valve. I went out back and ripped up some more stumps...No problems...Yet.I hope this resolves the issue. I would like to think that the first 17 hours I've put on her were gentle. I haven't pushed her too much.I hope she's able to be pushed a little more once I bump the RPM's up.Poor girl had to have things replaced and she's only a newborn.
Jason
PS: I'm glad to hear Clementine is ok.
   / Jezebel is BLEEDING!!!!!!!!!!!!!! #7
Jay,
Sorry to hear about your problem. I had a similar issue with the fluid leaking (Gushing more like it) from the hydro filter. I did learn here that there is a new part number for that filter. (Old Pn 32701-37950, NEW TA240-59900, if I copied it down right). After service, I have had no problems and I have been working with the FEL and Gannon Box blade hard. Although from the temperature gauge, the tractor seems to think I'm out for a Sunday drive!
I guess the moral of the story is that everything should be OK. No need to obsess on the past. You have a very good tractor that will last a good long time, it just had one teething problem.
Keep the faith!
John Bud
   / Jezebel is BLEEDING!!!!!!!!!!!!!! #8
I have the 3410HST and it now has apx 25 hours on her and I have been using it hard. Now leaks, grunts or groans so far. Sounds like you just had a bad part on her.
John,
Thanks for the reassuring words. I was just unsure if I was causing the problem, There was a faulty part, or it was just a fluke. I know that I payed for the dependability of Kubota tractors much like I payed a little extra for a toyota truck. I feel much better now that I was out with her last night ripping stumps up.Thanks
Jason
JLG 20MVL Electric Vertical Mast Lift (A50322)
JLG 20MVL Electric...
2010 Wilson Hopper Bottom Trailer (A50514)
2010 Wilson Hopper...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
New Holland L225 Skidloader (RIDE AND DRIVE) (A50774)
New Holland L225...
2018 Jaguar XE Sedan (A50324)
2018 Jaguar XE...
