Jery Dunn Tach-N-Go and Forks
   / Jery Dunn Tach-N-Go and Forks #12
Im looking for a QA for my BX. Is this more or less then OEM? Any differences?
It costs more, but Jery's QA is substantially more robust, is pinless with flip-style locking cams to engage the implement pins, has a built-in 2" receiver for easy trailer maneuvering, has built-in eyelets for chains or straps, etc. I posted pictures on my BX with his lightweight forks. Look them up. The differences are obvious. Good luck in your decision.
   / Jery Dunn Tach-N-Go and Forks #14
I too have talked to and ordered from Jery Dunn. I bought the Tach-N-Go for my BX2230 and I wanted the forks that go on it and will also go on the 3pt. My forks are the fixed forks, not the moveable ones that robertm has. I got the QA installed o the loader arms, and put the bucket back on for some January thaw snow pile moving, but have not used the forks. Snow blower is back on, so the FEL has been removed. I also wanted the 2" receiver in the QA. Have used that to move a 16' landscape trailer. That takes a bit to get used to. Been backing up trailers all my life, now drivng them backwards with the steering axle in the middle, takes a little thinking. Great products. Jon
   / Jery Dunn Tach-N-Go and Forks #15
I have have Jery's Tach-n-go and a set of the non movable forks they are really good quality, great welds and everything fit perfectly.
   / Jery Dunn Tach-N-Go and Forks #16
Pictures??
Here you go. Mine are movable, and each fork comes off the rack for easy storage. The rack can't weigh more than 40# and each fork maybe 30#.
   / Jery Dunn Tach-N-Go and Forks #19
   / Jery Dunn Tach-N-Go and Forks #20
Perfect setup, I soooo want this for mine. Thank you for all the pictures.
12 ft Shipping Container (A55973)
12 ft Shipping...
Willmar 4550 Wrangler Articulating Loader (A56435)
Willmar 4550...
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
2017 Freightliner Derrick Digger (A55973)
2017 Freightliner...
2017 Bobcat T450 Compact Track Loader Skid Steer (A56857)
2017 Bobcat T450...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
