Jerry in the Spokane Valley
/ Jerry in the Spokane Valley #1
jerryasi
Spokane Valley, WA
Cub Cadet 2135
My wife and I built a home on the back portion of her parents 2+ acre lot, lawn mower that is in use is a Cub Cadet 2135. Have had erratic starting issue, thought it was the PTO switch, I replaced it, still had problem, if while trying to start I wiggle the wiring harness to the switch it would catch and start. That also failed this past Friday, too much lawn for my walk behind Honda. Cleaned the terminal/plugs, looked like more than normal wear and tear. Now if I snap the PTO switch down it will eventually catch and start. I noted that a member, Jack Vines commented on the 斗awyer switches, I壇 like to talk with Jack. I知 retired, so more time than money, wiring not my forte. Jerry
/ Jerry in the Spokane Valley #2
Hi, Jerry. Welcome to the forum!
:welcome:
I'm going to move this thread over to our Cub Cadet section :)
/ Jerry in the Spokane Valley #3
Welcome to TBN & the forum. Wish I could be of help but my knowledge of wiring falls into the same basket as yours.
/ Jerry in the Spokane Valley #4
:welcome: to TBN from NH...enjoy.
/ Jerry in the Spokane Valley #6
Jerry,
The start issue you are talking about, is the problem that the engine does not turn over, or the engine turns over but does not run?
Richard
/ Jerry in the Spokane Valley #7
Often what happens is that each safety switch starts to build up some resistance as it ages and since several safety switches are in series like the very old X-mas lights, soon when you get to the starter solenoid, the power/voltage is too low to pull the solenoid in.
You can install a headlight relay to activate the starter solenoid easily. The low power/voltage will pull in the relay contacts and the relay supplies a true battery voltage to the starter solenoid.
You need to invest in a couple of cheap troubleshooting tools to be able to solve your problem in a progressive logical way without unnecessary replacement of parts.
The test light, which has a tiny bulb inside and a wire with an alligator clip on the end, enables you to quickly see if power is getting to your starter solenoid when you turn the key to the start position. You clip the alligator clip to a good ground, even the battery negative terminal and then hold the sharp end of the probe against the small wire terminal on the starter solenoid.
If the light goes on when you turn the key to start you have valuable information.
This first image shows a relay on an old cub cadet to make the solenoid engage. Simple wiring, all in one area.
Amazon.com: Neiko 4�5�8 83�B Digital Multimeter | AC/DC Voltage, DC Current, Resistance, Diodes, Transistor hFE Tester | Max Reading 1999: Home Improvement
There are simple ways to bypass the safety switches by applying battery bvoltage directly yo the starter solenoid terminal but this is danagerous if you are not that technically inclined. The unit could start with the blade engaged and your feet sticking under the deck, the mower could start moving. This is best done with an assistant in the seat with the brake on and you being extremely cautious. If this appeals to you we can discuss the details.
Right now as another forum member has asked you, it is not clear exactly what is not happening when you try and operate your mower.
Dave M7040
