Jerky FEL
/ Jerky FEL #1
DFW
Red Bluff, California
Task Master 432E
Someone using my tractor broke one of the cyclinder ends and had it fixed. After installing the cylinder, now the FEL is jerky and won稚 lift anything real heavy and the fluid is foamy. Do I need to bleed this, if so how? FYI, I致e got a small leakage from another cylinder, which has been like this for a while and never had a FEL lift problem.
Any ideas. FYI, tried searching but I didn稚 see anything along this line.
/ Jerky FEL #2
I'd check hose connections first follow by hyd. level.
/ Jerky FEL #3
If the fluid is foamy, then there is air in the fluid. This is usually caused by a leak on the return/suction side of the system so you often will not see a drip or leak. If he ripped a cylinder apart-then chances are there is damage under the tractor, possibly to the filter or return line that runs from the sump to the pump. If you keep using your machine with the foamy fluid then you run the risk of damaging your pump due to cavitation.
Key search words here are "foamy" and "cavitation"
(15) IH Suitcase Weights (A66408)
(15) IH Suitcase...
2015 John Deere CX15 (A64126)
2015 John Deere...
2017 Link-Belt 350X4 Hydraulic Excavator (A64553)
2017 Link-Belt...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
2015 VOLVO VN (INOPERABLE) (A65643)
2015 VOLVO VN...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
