3-Point Hitch Jerky 3 pt hitch movement with lifting post hole digger on DK40SE cab
   / Jerky 3 pt hitch movement with lifting post hole digger on DK40SE cab #11
I loosened the two bolts and fluid started coming out, so I quickly tightened them back down. Oops! Lol think I'll just take it to the dealer
   / Jerky 3 pt hitch movement with lifting post hole digger on DK40SE cab #12
Is your MLS valve on the top or bottom of the transmission?
   / Jerky 3 pt hitch movement with lifting post hole digger on DK40SE cab #13
On the top. Right under the seat
   / Jerky 3 pt hitch movement with lifting post hole digger on DK40SE cab #14
Also have the 3pt hitch down if your problem will allow. The MLS valve throttles speed of the 3pt hitch setting down, so their may be a bit a fluid you will see from this function. But even if it is up, the volume you will get out of the MLS will be limited to what that 3pt cylinder can hold. The majority of your fluid is down in your transmission lower half and will not leak out. Crack the bolts on the MLS valve until it starts to leak slowly, and let it drain this way into a pan, you will find it isn't very much fluid. Probably isn't a decent way to put a pan right under the MLS valve, so you may have to make a little oil channel. I just let mine drain down over the transmission and into a pan on the shop floor. In my instance I had a few cups of oil drain out.
   / Jerky 3 pt hitch movement with lifting post hole digger on DK40SE cab #15
@Amcane, Yes it takes some rattling of the brain cells to remember how it ended.
Based on the post I linked to in my first post, "The MLS only affects 3PH lowering speed, NOT raise speed/condition." So I am pretty sure I abandoned dealing with the MLS.
I am also pretty sure that my solution was not ideal. Namely to NOT lift the 3 pt hitch in little increments. It seems it works best / smoothest when the lever is thrown into raise mode. Sorry for the foggy answer. I can see this might not be satisfactory when raising or lowering a snowblower. I have my blower on the front and so don't use the 3 pt hitch. Let me know what you have found out in the spring. Also read that first post, if you haven't already. It has some good information in it.
Kinda ironic that you mention my post in your OP, and said that I never came back with the resolution (but promised to do so, yourself), when I actually posted the same end-result in the thread you mentioned, a year before your OP, and you waited another 3 years to come back and say the same.
In the end, mine raises, lowers, and holds position smoothly. It's just when I try to raise it really, REALLY slowly that it is jerky.
A couple years ago, in trying to make sure that mine was fine, I did end up removing and disassembling the MLS valve, per the service manual, but I didn't find any issues like @xcgreene described below. Mine was properly assembled and in good condition. I also ran through the sensitivity adjustment procedure twice, testing for jerky slow lifting along the way, and arrived at exactly the original setting both times.
In the end, this is the first 3ph that I'd spent any significant time with, and I think it was my lack of experience showing. It seems there is just a limit to how slowly you can raise one smoothly.
Should anyone stumble on this thread with a jerking 3pt hitch in a new tractor, I thought I would offer this up. On One of my DK45SEH I had a jerking 3pt hitch when the tractor was brand new. No adjustments or methods really helped at all. I removed the MLS valve, (after removing the operators seat you can unbolt the MLS and pull it right out), whole thing is about the size of a beer can, maybe a bit bigger. There is a needle valve held down by a spring, you can see it clearly on the side of the MLS valve itself without having to disassemble it further. The needle was sidways in its slot, obviously an issue from the manufacturer of the MLS valve. I simply removed the spring and needle, set it in properly, threw it all back together and BINGO smooth as butter. No special tools needed for this exercise. I was working with Kioti at the time to try and solve the problem, This particular dealership was admittedly only sufficient for basic service, but they were allowing me to do the work in my own shop while they would provide me with any parts needed. I reported back with the findings and they sent me a brand new, $800 MLS valve in exchange for the repaired one. There was nothing more wrong with that MLS valve after repair, the needle valve seat look fine and 3 point hitch functioned as it should, but they obviously needed the MLS valve for a number of reasons. I hope this may help someone who is having problems using their 3pt hitch for the first time.
   / Jerky 3 pt hitch movement with lifting post hole digger on DK40SE cab #16
The issue you are dealing with concerning the 3 point hitch function has nothing to do with the flow valve located under your seat. It is the 3 point valve and there is nothing wrong with this valve. The valve is a single function valve. Basic as it can be. It is build up pressure to go Up or release pressure to let Down, only. Therefore, you can not feather. Kioti uses this minimal valve to offer as many features possible at the lower price.
This makes total sense. Thanks for explaining. I guess that's the good news / bad news. You can't make it do something it wasn't designed to do. However, having implements coming up toward the back cab window at full speed is a recipe for disaster. There is barely any extra room between some implements (e.g. post hole digger) and the cab and I've been concerned about busting the back window from accidental impact. I ended up with a broken back window a year ago and it's likely from something like this.
Anyway, thanks for confirming the price of my cost savings by going Kioti.
   / Jerky 3 pt hitch movement with lifting post hole digger on DK40SE cab #18
Well, don't get me wrong. I am absolutely in love with my DK4210SE HC. It does everything I ask of it. But like others I was concerned with the 3 Point movement and researched it. For me, here's what I've found with my tractor. After learning about the valve's simplicity, instead of slowly and gradually lifting the 3 Point (as I have done with all the older tractors), I get right to the point. Example, I was very concerned about the PTO linkage on my tiller going to too much of an angle. What I do with the Kioti is go straight from down to 7. 7 seems to be a good raised position height for my tiller. When I pull back on the position lever, I do it quickly, right to 7. When I do that it goes smoothly, right to the height I want. So basically I have compensated myself to the tractor. As for the price of saving money, you right!, you right! It's like that with everything. However, it is possible to have the valve upgraded. It's a pretty penny if you have a shop do it. But even then, it comes no where close to what I would have paid for another brand that comes standard with a valve that can smoothly feather. But I fully expected that. I immediately customized mine. I've replaced the 4 work lights and added 4 by installing 8 LED floods around the brim of the cab. It's like a halo of light. It fully lights up more than a 3/4 acre around me like daylight for $76 and $12 for the switch. The seat belt ends were jamming into my backside. So, I extended them out just a bit with Grade 8 bolts and spacers for a few bucks and added a back up camera and a magnetic camera for the FEL that sticks on the bucket or forks. I am a happy boy. So, if there features you want/need, add them. You've still saved a metric crap tonne of cash.
30pc. 16ft.x 3ft. Black Metal Roof Panels (A53424)
30pc. 16ft.x 3ft...
New/Unused Sd Lanch SDLJC Mobile Jaw Crusher (A54865)
New/Unused Sd...
flooring (A55758)
flooring (A55758)
2015 FREIGHTLINER CASCADIA DAYCAB (A55745)
2015 FREIGHTLINER...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
Toro 880 Procore (A55758)
Toro 880 Procore...
