Jensen radio in excavator damaged by hot weather.
   / Jensen radio in excavator damaged by hot weather. #1
plowking
Nottingham, N.H.
2009 MF 1531 TLB
I wondered what you guys use for radios in your equipment? My kubota min excavator has a Jensen radio it mounts on a bracket. The extreme heat this week killed it .Is there a good radio you can buy to take out of machine when not in use so it doesn't get damaged. My machine has a cab with ac. Thanks.
   / Jensen radio in excavator damaged by hot weather. #2
I'm thinking that your radio failure was coincidental, temperatures here in New England weren't THAT hot...low-mid 90s maybe but that shouldn't harm a auto radio.
What kind of air circulation is there around where it's mounted?
Its mounted to right of operator by the window .Machine sits in the sun. Have no shade in yard .My temp. at house been 86- 94 all week.
   / Jensen radio in excavator damaged by hot weather. #4
Never considered Jensen to be a high quality receiver in the first place. it's what RV makers use and they tend to use cheap components anyway. made in China with a domestic name...
   / Jensen radio in excavator damaged by hot weather. #5
Mine has a Pioneer radio that I installed when I got it. It's just a standard radio. I don't really think it's the heat that killed yours since all the cars sitting out there have radios in them and this isn't a problem with automobiles.
If the sun actually beats down right on the face of the radio, you could lay something over it just to shield it from the direct sunlight. Just a thought. . .
   / Jensen radio in excavator damaged by hot weather. #6
Put your baseball cap on it. Every operator I know of wears one...
   / Jensen radio in excavator damaged by hot weather. #7
In the unlikely event the heat actually did kill it it happened when the machine was parked and closed up vs in operation.
   / Jensen radio in excavator damaged by hot weather. #8
Do you have the ability to leave a window cracked when its sitting in the sun unused? I find this helps the interior temps on vehicles.
   / Jensen radio in excavator damaged by hot weather. #9
You could mount it in a sliding removable mount. They were common for CB radios. I used one for an under dash radio/cassette player/equalizer amp for many years back in the 70s and 80s.
LMC LOT IDENTIFIER 130 (A53084)
LMC LOT IDENTIFIER...
2015 Volkswagen Passat Sedan (A51694)
2015 Volkswagen...
KUBOTA KX057-4 EXCAVATOR (A51246)
KUBOTA KX057-4...
2017 Nissan Altima (A51694)
2017 Nissan Altima...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
