JD955 v's JD790, 990 or 3x20 series
   / JD955 v's JD790, 990 or 3x20 series #1
llccprof
Hello Everyone,
This is my first post to the forum, although I have been reading it for some time now.
Here is my question:
I am looking to purchase a CUT. I recently sold my 4720. It may have been more machine than I needed, but with all of the bells and whistles it had, I was worried about the cost of fixing it if anything every broke on it.
I recently purchased a 430GT just for mowing and am finding out that I will need something bigger and that is why I am looking again for a CUT with less bells and whistles than the 4720.
I would like your overall opinions on the 955 v's the 790 and 990. I like the size of 955 and 790 but I worry if they will not be as stable as the wider 990 for mowing steep slopes. I also find myself leaning toward the 990 for the extra hp and weight but I do not want a maching as big as the 4720. How does the 990 compare to the 4720 with regard to size?
Thanks,
Jim
   / JD955 v's JD790, 990 or 3x20 series #2
As far as size, a 990 (currently known in Deere's line up as the 4005) is the same size as a 4720, so you wouldn't really be changing anything as far as size. One thing to remember about the 790 and 990 is that they are both gear driven tractors. If a hydro transmission is something your looking for, but in a bare bones configuration, then I would suggest taking a look at the new 3E series machines. The 3032E and the 3038E, which come standard with a hydro transmission and have an available fixed, non-removable loader.
   / JD955 v's JD790, 990 or 3x20 series #3
The 955 and all the x55's (755/855/955) are pretty much bulletproof.. Good machine.
Only problem with them IMO is buying them used...hard to find a good deal on them.
I'd probably lean towards what WH401 said and look at a 3032E... None of the 8/955's I've seen for sale around me have been at a price I'd consider "reasonable" for what your getting...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
2008 BigTex Utility Trailer (A50860)
2008 BigTex...
2021 Chevrolet Silverado Pickup Truck (A50397)
2021 Chevrolet...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2016 FORD F550 CREW CAB SERVICE TRUCK (A50505)
2016 FORD F550...
